Old 01-24-2026, 07:59 AM   #1
ms fowler
Default Installing back glass in '38 pickup.
I am "helping" a friend get his '38 pickup back together. Last Fall we tried to install the rear glass. I had convinced him to get a fresh gasket as the old one was hard as wood. The install seemed to go OK, except for one little place where the glass just seemed to stop. Of course, in forcing it we broke it. Replacement glass is available, but is it normal to have to trim the glass or the edges of the opening? That same glass had come out, yet it did not want to go back. Is there a specification for clearance between the glass and the opening?
( I offer that same level of help to all my friends)
ms fowler is offline   Reply With Quote
Old 01-24-2026, 12:23 PM   #2
325w
Default Re: Installing back glass in '38 pickup.
Used glass is very hard to reuse. Get a new glass. Lube the new rubber real heavy. Go Joe hand cleaner work s good. Dish soap and water works good also. Keep metal tools away from the new glass. Warm the rubber gasket. Everybody has their way to install. I’d set the glass onto the center of the opening. Go left and right slowly. Might check the opening for sharp edges like a spot weld close to the edge.If you have a hose release tool it works good around the outside side
325w is offline   Reply With Quote
Old 01-24-2026, 12:36 PM   #3
glennpm
glennpm's Avatar
I use Ru-glyde for mounting tires and would work very well for the glass installation too.
https://www.agscompany.com/products/...t-bottle-1-gal
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 01-24-2026, 02:51 PM   #4
KiWinUS
KiWinUS's Avatar
Did you use nylon rope?
Old 01-24-2026, 07:40 PM   #5
38bill
38bill's Avatar
The 38 pickups use flat gaskets for the rear window. Not too surprising that the glass and maybe the opening would need to be tweeked.
38bill is offline   Reply With Quote
Old 01-24-2026, 10:33 PM   #6
51504bat
51504bat's Avatar
And never use WD40
