how does one re use those under dash metal (lead?)connectors that connect the throttle rod in dash to rod from carb?
it's on a 1936 Fordor
My '34 has little metal sleeves about an inch long with two threaded holes and very small set screws.
Crimp with really good wire terminal crimpers for uninsulated wiring terminals.
You can also use a good quality epoxy adhesive to make the joint. The original Ford specification was the joint should be able to withstand 100 pounds of pull force.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
My experience with the connectors was that they were so hard they would not crimp properly, so I located then with the choke and throttle names aligned with the connectors located, then removed them and used a wire feed welder to spot weld in place. Just my solution.
thanks all!!
Super Moderator
I use my wire fencing ferrule crimping tool. Similar to an electrical wire connector tool but MUCH more heavy duty.
#10 | |
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
I very easily threaded the little reproduction seeves and the ends of the reproduction
choke and throttle rods. Works really well. |
Super Moderator
Thanks Glenn. That's the tool indeed!
#13 |
Kube, I like the fact that I'm not the only one here who builds and repairs fence also.
#14 |
I made my own, used a couple of like 1/4 diameter (or 5/16th's) 3" long Stainless Steel bolts. Cut the heads and threads off of them, drilled two holes in each end and tapped them for 6/32 set screws. Then mic'd the choke and throttle rod shafts and drilled the hole down the center on my lathe!!!
#15 | |
Super Moderator
Twelve horses, eight pastures... LOTS of posts and wire. I'm getting old methinks.
#16 |
#17 |
#18 | |
Super Moderator
#19 |
Will JB weld hold them? Has anyone had luck with that?
#20 |
I don't think that there would be enough epoxy between the rods and the connector even with a filet of JB Weld on the ends. You may be better off soldering it, buff, clean, flux and solder. Crimping is the best way though.
