Old 09-24-2025, 11:42 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Poll Regarding Accessory Gauges You Prefer
This post is a poll to determine your preferences for the type of accessory gauges you have or would install in/on your Model "A". Choose from the choices listed:
Clock
Coolant Temperature Gauge
Electronic Tachometer
Manifold Vacuum Gauge
Motometer
Oil Pressure Gauge
Motometer
Thermoquail
Voltmeter Gauge
Bob Bidonde
Old 09-24-2025, 12:00 PM   #2
Zax40
Zax40's Avatar
Default Re: Poll Regarding Accessory Gauges You Prefer
Coolant temp gauge for sure. Now that I have one I would not go back to having an A without one
Zax40 is offline   Reply With Quote
Old 09-24-2025, 12:13 PM   #3
Mulletwagon
Mulletwagon's Avatar
Engine temp amd oil pressure.
Mulletwagon is offline   Reply With Quote
Old 09-24-2025, 12:15 PM   #4
2speed
Temp and oil pressure. I also have a voltmeter that was helpful in a diagnosis.
I have a Burtz, on a stock Model A, oil pressure I'm not sure I would need, but temperature is a must.
2speed is offline   Reply With Quote
Old 09-24-2025, 12:16 PM   #5
Chuck Dempsey
Chuck Dempsey's Avatar
Just a clock...and an outside temp gauge. Not on your list, but would be nice to have.
Chuck Dempsey is offline   Reply With Quote
Old 09-24-2025, 12:39 PM   #6
J Franklin
J Franklin's Avatar
I have none and will keep it that way.
Old 09-24-2025, 12:55 PM   #7
ModelA29
ModelA29's Avatar
Just one - water temp. Our Coupe came with a Brassworks pressure radiator a thermostat housing and old style Stewart Warner wing gauge.
Our Tudor has no gauges but as long as the muddy looking water isn't puking out of the radiator I figure it's OK.
ModelA29 is offline   Reply With Quote
Old 09-24-2025, 01:10 PM   #8
nkaminar
nkaminar's Avatar
In order of checking frequency:
  1. Speedometer. (GPS, my speedo not accurate)
  2. Voltmeter
  3. Ammeter
  4. Gas gauge
  5. Temperature (at coolant outlet aka goose neck)
  6. My wrist watch
  7. Oil pressure
  8. Tachometer
Old 09-24-2025, 01:37 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
Header rim wind clock and motormeter
The model T the only modification is stop lights
Old 09-24-2025, 02:46 PM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
No GPS??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-24-2025, 03:04 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by BRENT in 10-uh-C View Post
No GPS??
Haha, I do have Ms. Garmin suction cupped to my windshield At least it has a Model A for the cursor). Doubles as my Speedo and Odo since my "Rebuilt" Speedometer does not read correctly. And it helps me find my way home...
I also have a Water Temp and a Moto-Minder. Plus a clock in the rear mirror.
Old 09-24-2025, 04:24 PM   #12
Synchro909
Synchro909's Avatar
Coolant temperature and because my cars have oil pressure, a gauge for that too.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 09-24-2025, 05:46 PM   #13
mcgarrett
My shifter knob clock and Rex-A-Co temp gauge!
Old 09-24-2025, 08:55 PM   #14
Ayers1
Ayers1's Avatar
I have oil pressure and temp gauge in my A's. I figure that's all I need to keep an eye on things.
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Ayers1 is offline   Reply With Quote
Old 09-24-2025, 09:22 PM   #15
Brad in Germany
Brad in Germany's Avatar
I can't decide so they stay in the display case:
.....etc.....
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 09-24-2025, 09:24 PM   #16
grumpy dude
grumpy dude's Avatar
coolant temp.
grumpy dude is offline   Reply With Quote
Old 09-24-2025, 11:11 PM   #17
Herb Concord Ca
I have temp gauge in both my A's and a recently added Tach in my touring car.
Herb Concord Ca is offline   Reply With Quote
Old 09-25-2025, 01:07 AM   #18
German guy
German guy's Avatar
Clock? No. I wear a watch.
Coolant Temperature Gauge? YES!
Electronic Tachometer No. My hearing is still good.
Manifold Vacuum Gauge. About as necessary as an altimeter
Motometer No
Oil Pressure Gauge No
Motometer
Thermoquail a nice decoration but not a gauge
Voltmeter Gauge I do not need to know while driving
German guy is offline   Reply With Quote
Old 09-25-2025, 08:46 AM   #19
Chris in WNC
Chris in WNC's Avatar
coolant temperature gauge when I was driving long tours in the summer.
none needed for my beater truck just driving locally......
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 09-25-2025, 08:55 AM   #20
Big hammer
Side note : modern cars are getting away from touch screens and going back to knobs and buttons ! About time IMO
In my carry tool box I have IR temperature gun, VOM, a test light, a screw driver for removing the oil plug on the side of the engine to check for oil flow, a calibrated wooden stick for double checking the gas level.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
