At this point I'm trying to take apart a '40 column shift. The problem is at the bottom where the shaft goes into a two part assembly that is attached to the steering column tube. I have the bottom part of the assembly removed, but the top part will not release from the end of the shift tube. There is a pin that drops into a hole in the column and I have lifted the shift tube up the clear the hole, but this piece will not slide off the shift tube. What am I missing here? Thanks for any and all advice.
Maybe this parts picture from Vanpelts will help.
I’m assuming you’re referring to part number 7318 ? Once it’s lifted offf the column it should slide off.
You have removed pin 7337?
No, it's still all together. Terry brought up a pin # 7337 which apparently holds everything together. I just called another V-8er and he advised that pin needs to come out. I appreciate everyone's advice and those that posted the diagram.
Very helpful. Now back to the garage and get out the pin. |
#11 | |
![]() Quote:
