What size clutch can I expect to find in my ‘41 long door coupe. Did Ford only use one size for automobiles? I guessing my car was made between April and June of ‘41 based on serial # and glass date codes.
Probably a nine-inch but there was a switchover and as such many were equipped with a ten-inch assembly.
If you happen to have access to the inspection cover at the front of the trans, you could look in there. A flat flywheel is gonna be a 10", and the thick blob flywheel is gonna be a 9"
JMO but if you need a new clutch stay away from Ft. Wayne Clutch. They used to be a go to source. Today, not so much.
Thanks for the info.
Well, yeah, maybe. Every clutch replacement I have done (too many to recall) I have cut that bell off of the flywheel.
Not just your opinion. Mine as well as many others too.
Someone in a similar thread listed a shop in KY (I think) that is still rebuilding them the correct way.
Tim, That's the place I went to after Ft. Wayne turned bad. That place is awesome!
Vintage clutch kits is in KY
https://kyclutch.com/
KY Clutch and Performance, Inc. 250 Gun Club Road Brooks, KY 40109 (502) 955-9173
#13 |
Kube, you cut the "blob" I call it, off all your flywheels? I do too. Two reasons, one, the writings of late great Rumbleseat, and Bruce Lancaster, thats the lightest "Ford "flywheel you can have without buying some aftermarket piece. Two, I have a lathe, so its fun and has no cost. You, a retired tool and die maker..I assume you have lathe at home too, So no cost. In the real world, I doubt the corner gas station that put the last clutch in in 1965 or so, would recommend the customer to pull the flywheel and send it out to a machine shop. The OP's car seems pretty original, so my statement would stand unless someone put a truck motor in with an 11" clutch. Not likely on the OP's car. The 9" flywheel with the blob cut off is a remarkable difference. They wind up fast, and decelerate fast, making shifting easier and you think you gained a bunch of HP.
Henry, and the rest of the industry at the time, believed in heavy flywheels. Model A's are 60 lbs! I forget the v8's, and what you loose by cutting off the blob, old brain seems to delete more than it takes in these days! |
#14 | |
![]() Quote:
I did balance all flywheels prior to installation.
#15 | |
![]() Quote:
Like Cas3 mentioned, it is surprising how much liveness it adds to the engine without so much moving mass on the end. |
#16 |
I have cut the heavy ring off and can confirm it does need to be balanced afterwards. I did mine by a home brew method which seems to have worked ok. Lathes are great.
#17 |
I went w a 10” in my ‘35 Tudor & have enjoyed it for years! The pressure to push is almost not noticeable! Some advise, I experience a situation that stumped me & others. I requested a 10” assy on my ‘49 8ba engine I was having built. Obviously the builder didn’t notice the vibration during the bench test stand. I installed it n my ‘35 w a rebuilt ‘39 tranny & over 1000 rpm the vibration was terrible. Long story short, it was the 10” clutch flywheel. It was n 11” flywheel redrilled as a 10” & was out of concentric .075”. After months of trying to find the problem I finally had an experienced Early Ford mechanic discover it. He installed a correct 10” flywheel in & it purred with no vibration! He said it was pretty common w guys wanting to replace the 9” assy w a 10” so they’d get a junked 11” & use the 9” as a drill fixture instead of having it done on a boring mill or Bridgeport mill.
Best of Luck on your project! Tony
Nomad Last edited by AnthonyG; 06-30-2025 at 01:11 PM. |
#18 | |
![]() Quote:
To think as some do, they can simply "get it close enough" by marking the holes in a clutch plate is laughable.
#19 |
I've done redrilling using a rotary table and have shown it many times in my videos.
All this talk about clutches - is it clutch chatter? Mart. |
#20 |
Groan
