Old 06-03-2025, 06:53 PM   #1
jack99
Default Condenser?
Is the fiber washer neccessary when replacing the condenser?
jack99 is offline   Reply With Quote
Old 06-03-2025, 07:04 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Condenser?
How much would the factory save if they didn't use the fiber washer in the millions of cars they made?
Old 06-03-2025, 07:52 PM   #3
1955cj5
1955cj5's Avatar
discussion here......
https://www.fordbarn.com/forum/showt...2502&showall=1
I think the answer is "yes".
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 06-03-2025, 09:03 PM   #4
2speed
My repro cable went bad, I want the skinny screw in ignition cable and it's out of stock, so I just took a piece of wire and put a terminal end on it and screwed it to the condensor. I lost the screw and washer in the process, and now I have an allen screw holding it on with no washer. The allen SHCS makes it super easy to install and I've had no problems. You can get away without it.
2speed is offline   Reply With Quote
Old 06-04-2025, 12:07 PM   #5
rotorwrench
rotorwrench's Avatar
It's to prevent flash over of high tension voltage. Now days folks use DC4 silicon grease or equivalent to coat stuff for spark flash over prevention.
Old 06-06-2025, 07:16 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
I have never used the fiber washer being discussed, and I never had an issue because of not using it. Moreover, I do not see it listed in the July1, 1931 Parts Price List.
Bob Bidonde
