Old 01-29-2024, 02:59 PM   #101
Ol' Ron
Ol' Ron's Avatar
Default Re: 4bbl carb on flathead?
YES!! Thats the intake I'm using.
G
Old 04-25-2025, 06:26 PM   #102
52Mercman
Originally Posted by 38 coupe View Post
38convsedan, you are running an 8BA yes? Are you currently running the stock distributor and carburetor? If yes, be aware you will also have to change the distributor when you go away from the stock carburetor.
The 500 cfm four barrel is probably larger than your engine will like.
So I have installed the Edelbrock 1404 on my 239 and get black fouled plugs.
Changing timing will improve response sitting in the driveway but its a pig on the road and fouls the plugs black. I have the stock distributor and just purchased a good fuel pump and regulator. They just arrived but I haven't installed yet. Edelbrock says 5.5 on pressure and I already know voltage is an issue in keeping it consistent but if this doesnt work what would you recommend for a distributor?
52Mercman is offline   Reply With Quote
Old 04-25-2025, 06:48 PM   #103
tubman
tubman's Avatar
I'll try one more time. What year engine and car? If it's a post '49 8BA engine, it has what is called a "Load-A-Matic" distributor whose advance system will only work with certain Ford carburetors and your Edelbrock ain't one of them. You will need to change the distributor out for an aftermarket mechanical advance unit or a converted SBC distributor. If it's an earlier model engine, you can still use the stock distributor.
If you are trying to run an otherwise stock 239 ci engine with 500 cfm carb, you're probably have to make some changes to it (jets, etc.) to even get it close. A better choice would be a 390 cfm Holley or a Rochester 2G (which needs different manifold).
Old 04-25-2025, 09:03 PM   #104
52Mercman
It's a 52 8ba in a F3.
It's a brand new carb which was recommended to me by Edelbrock, with the matching adapter plate and manifold.
Engine is sound with 95 psi on all 8 cyl. good valves. Very clean inside, it was tore down and inspected. It ran perfect on original carb but my son talked me into this so the money spent but I need to get this back on the road. It's not a parking lot princess, it's my farm truck.
Old 04-25-2025, 09:20 PM   #105
tubman
tubman's Avatar
Farm truck? Put it back to stock and quit listening to your son.
Old 04-25-2025, 11:37 PM   #106
Scotty's 52 F3
Scotty's 52 F3's Avatar
My 52 F3 had the Load-A-Matic also. Like mentioned it will not work for you on any carb other than the stock one.
A good option is to get a GM unit adapted to fit your engine with the correct advance curve. It will run great. You will still have to tune your carb but you won't be fighting your ignition as well.
Charlie NY sells converted distributors that he runs on a test engine before shipping to you. He usually has points or electronic and GM or Mallory and is a great guy to deal with that stands behind what he sells.
Charlie Schwendler (716) 662-9159 [email protected]
Scotty's 52 F3 is offline   Reply With Quote
Old 04-25-2025, 11:41 PM   #107
Scotty's 52 F3
To add, Charlie rebuilds the stock carbs and fuel pumps as well. If your original carb and distributor need to be freshened up, he can do it. It will be bolt on and go when you get them back.
Good luck with your truck and please follow up with whatever you decide.
