Old 03-29-2025, 08:18 AM   #1
dac
Default oil Pressure & Water temp. gauges
Oil pressure and water temp are the gauges I am trying to hook up. How do you hook up the two gauges to the electric and where does that connection occur? I am piggy backing the two together but then it needs to go to a power source that will only be turned on when the key is turned on. Thanks in advance. They are mechanical gauges.
dac is offline   Reply With Quote
Old 03-29-2025, 10:24 AM   #2
Will N
Will N's Avatar
Default Re: oil Pressure & Water temp. gauges
IMHO, I would hook'em up by putting them back in the box and returning them to the store. The oiling system in the A does not produce pressure- the pump output fills up the valve chamber and gravity does all the oiling- in addition to the dippers on the conrods splashing oil all over the place. As for a temp gauge, I know people who have them who become mesmerized watching the temp go up and down as they climb and descend hills, worrying their car is overheating. You'll know when its overheated when it's steaming!
Will N is offline   Reply With Quote
Old 03-29-2025, 10:36 AM   #3
Marshall V. Daut
Oil pressure in a Model A engine will be about 6-8 pounds when first started up, dropping fairly quickly to about 3 as it warms up. I agree that an oil pressure gauge in a Model A can become rather boring to watch for lack of needle movement, but the one advantage I can think of is that it will tell you immediately if the pump has failed = the needle will drop to zero. It's probably too late by the time you notice that, unless you glance at the gauge every couple seconds. But when has a Model A oil pump really failed while driving, unless the screen becomes so clogged with crud that the pump can't circulate oil? Once again, though, that's got to be a fluke incident.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 03-29-2025, 10:38 AM   #4
rfitzpatrick
@ WILL N: Now that's what I like: A Kind/Thoughtful Response
rfitzpatrick is offline   Reply With Quote
Old 03-29-2025, 10:57 AM   #5
Bob C
If you have mechanical gauges then the only power you would need is for the lights. Run a wire from the tail light for power.
Old 03-29-2025, 11:13 AM   #6
Hitman
Especially for someone that just joined the forum and was asking a question. Will’s response was a poor welcoming.
Hitman is offline   Reply With Quote
Old 03-29-2025, 11:48 AM   #7
johnbuckley
johnbuckley's Avatar
Originally Posted by Bob C View Post
If you have mechanical gauges then the only power you would need is for the lights. ....
I agree. If they're mechanical they only need the electric to illuminate them- join the wiring into the tail light circuit if needed. However, on the original circuitry of the Model A there is no circuit which only becomes live with the ignition - so if you have gauges that are electrical , then maybe the way round that conundrum would be to fit a battery isolator switch - a useful thing anyway.
Old 03-29-2025, 12:00 PM   #8
Jim Brierley
Originally Posted by johnbuckley View Post
I agree. If they're mechanical they only need the electric to illuminate them- join the wiring into the tail light circuit if needed. However, on the original circuitry of the Model A there is no circuit which only becomes live with the ignition - so if you have gauges that are electrical and then maybe the way round that conundrum would be to fit a battery isolator switch - a useful thing anyway.
With a stock electrical system, the answer above is probably the only way. When key is turned on it merely grounds the coil, no power is activated. Your electric gauges require a hot wire to one terminal and the other terminal goes to each gauge separately. Don't expect much, or any, movement on the oil pressure ga. Have fun!
Old 03-29-2025, 12:33 PM   #9
katy
katy's Avatar
What he said.
Old 03-29-2025, 01:33 PM   #10
Marshall V. Daut
The small light bulbs used to illuminate the water temp and oil pressure gauges probably don't draw much current. If the owner wants them to be operated when the ignition key is turned on, the wires will somehow have to be incorporated in the ignition switch head circuit. This would not be a problem with aftermarket switches with contacts exposed on their backsides. Just connect the wires to one of those two terminals. But how would you do this with the original "theft-proof" popout switch? Would you run the wires to the ignition coil terminal post (+), which is where the lone wire from the original switch head is connected?
When the electronic ignition modules first hit the restorer community in the early 1990's, some of us found how the hard way NOT to run accessories such as an electric fuel pump for downdraft carburetors directly to the ignition switch. I fried an expensive module doing that. I don't recall the solution people came up with, but it entailed hooking up such accessories not directly to the switch, but to an intermediary device. My point relating to the topic under discussion here is: Will hooking up those two gauge light wires directly to the switch cause likewise problems, or is the electrical draw too small to mess things up? 'Something for the poster to consider.
Marshall
Old 03-29-2025, 01:41 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
It would depend on how the car is wired— on a stock original car it would interfere with the points because the ignition switch is connecting the points to the coil.
Old 03-29-2025, 02:13 PM   #12
Ayers1
Ayers1's Avatar
For your information, this picture shows how to rewire an A for everything to operate through the ignition switch. I have an electronic oil/temp gauge on mine and have it wired this way.
File Type: jpg Screenshot_20230801-205333_Samsung Internet.jpg (24.8 KB, 72 views)
Ayers1 is offline   Reply With Quote
Old 03-29-2025, 02:59 PM   #13
ModelA29
ModelA29's Avatar
This is a toss up question. If the car is 12volt neg ground I'd use the electric gauges. If it's still 6v mechanical gauges are the way to go. I'd only install a water temp. There is a single bracket that fits below the speedo and looks like it belongs. As others have said monitoring oil pressure is not critical. You'll want to find a gauge that reads 20 pounds max just so you can see the needle move. Most new gauges are 60-80 pound. I've seen gauges screwed into the oil galley on the right side of the block. I'm going to do that when I finish the restoration of my old MotoMeter oil gauge.
My temp gauge is boring to watch. With my Brassworks pressure radiator, thermostat and plastic fan it's always glued at 160. It might be fun though to watch a passenger worry about the imminent explosion under the hood watching you drive around with 3 pounds of oil pressure on a 60 pound gauge.
ModelA29 is offline   Reply With Quote
Old 03-29-2025, 03:48 PM   #14
Y-Blockhead
Y-Blockhead's Avatar
I like your drawing...
Old 03-29-2025, 04:43 PM   #15
Ayers1
Ayers1's Avatar
Courtesy of some fellow a couple of years ago! ��
And I appreciated you sharing it back then!
Old 03-29-2025, 06:21 PM   #16
dac
Thank you!
Old 03-29-2025, 06:25 PM   #17
dac
Thank you for this information. Do you run 12V instead of 6V?
Old 03-29-2025, 08:06 PM   #18
Ayers1
Ayers1's Avatar
No, I run a stock 6 volt positive ground system. It has been suggested on previous threads that if you run everything through the switch then you should add a relay to take the load and keep the switch from burning up.
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Old 03-29-2025, 11:09 PM   #19
Y-Blockhead
I would not recommend running "everything thru the switch", just the items you want on when the engine is running.
And yes, run a relay if you have some high powered device.
Snyder's, and possibly others, have an ignition switch with an accessories terminal if you want to go that route.
Old 03-29-2025, 11:37 PM   #20
ModelA29
ModelA29's Avatar
Don't rely on the usual parts store replacement switch. There is limited room behind the panel so you need the shortest one you can find.
