Old 03-20-2025, 06:57 AM   #1
luke72
Default Blackstone fuel pump rebuild kit
hi all
looking around to understand who sell a Blackstone flathead 59A fuel pump rebuild kit, i have contacted a few people in the USA but at moment no answer anyone did it before and can suggest?
thanks
luke72 is offline   Reply With Quote
Old 03-20-2025, 07:57 AM   #2
pistonbroke
Default Re: Blackstone fuel pump rebuild kit
Interesting, I've not come across one of those pumps in all my years of flatheading.Tim
Old 03-20-2025, 08:34 AM   #3
luke72
they are not common, i have seen somewhere they use to call them racing fuel pump
Old 03-20-2025, 09:39 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
As I posted on the HAMB, get in touch with Charlie . . . he's done some "strange" pumps for folks (including me!).
Charles Schwendler
5845 Cole Rd.
Orchard Park, N.Y., 14127
eMail: [email protected]
Old 03-20-2025, 10:45 AM   #5
petehoovie
petehoovie's Avatar
Originally Posted by luke72 View Post
hi all
thanks
Old 03-20-2025, 10:59 AM   #6
luke72
Charles Schwendler
5845 Cole Rd.
i have discussed with charlie he doesn't have any kit, i'm waiting input if i should send in USA the pump for rebuilding job
thanks
Old 03-20-2025, 11:00 AM   #7
luke72
any input from you Pete?
Old 03-20-2025, 11:07 AM   #8
petehoovie
petehoovie's Avatar
For lack of a rebuild kit with ethanol proof innards, I sold the one I had several years ago...
Old 03-20-2025, 12:13 PM   #9
Bored&Stroked
I'd take it apart and see what the diaphragms look like . . . maybe ones from another brand/type of pump can be used. Did Charlie say that he had any experience looking in to the guts of one of these or not?
Old 03-20-2025, 01:34 PM   #10
luke72
Charlie i know he did one of this because i have seen it on the Hamb many years ago , the only solution will be to send t ohim, the one i have is NOS then should be ok to drive as it is , but normally i prefere to restore before use because the gas it's not the same today
Old 03-20-2025, 02:23 PM   #11
Bored&Stroked
NOS doesn't mean squat with old pumps . . . you're making a great assumption that the diaphragms are in good shape. Before I'd put this on my car - I'd make damn sure it was gone through. Think about what can happen when a diaphragm ruptures . . . not good!
Old 03-20-2025, 03:58 PM   #12
jimTN
The diaphram in a Blackstone is just a sheet of rubber or some sort of rubber fabric. It pumps with pressure from the air side of the pump. I once had a instruction sheet and over the years have lost it. If anybody out there knows which push rod and length of the rod to use with which pump I would appreciate it. I have a couple of those pumps.
Old 03-20-2025, 06:17 PM   #13
signsup
I think there is a pump for sale on the swap meet section on this forum .
signsup is offline   Reply With Quote
Old 03-21-2025, 04:33 AM   #14
luke72
in my knowledge the original push rod based on your engine should work , tiny and short for 59A and bigger on 8BA but not sure 100%
Old 03-21-2025, 04:34 AM   #15
luke72
thanks i have sent a couple of mails let's see what will pop up
Old 03-21-2025, 04:35 AM   #16
luke72
this is why i'm looking for a rebuilding kit, but now i'm thinking should i struggle all the time to run this pump? i'm starting getting tired
Old 03-21-2025, 04:59 AM   #17
hotcoupe
hotcoupe's Avatar
Hello, I have the same pump, and purchased a re-build kit for it. The kit was supplied with an ethanol resistant diaphragm. I don't have time to look for the supplier right now, I'm recovering from a medical issue and cleaning up after a severe weather storm. Give me a couple of weeks, and I'll try and find the supplier. Hang in there, the re-build kit is available.
Tom
hotcoupe is offline   Reply With Quote
Old 03-21-2025, 07:14 AM   #18
luke72
Tom
that's great, take care hope soon you will be on the road and can give me good input
thanks
Old 03-21-2025, 08:55 AM   #19
Bored&Stroked
Good News! If you find a supplier, buy a COUPLE kits as I can't imagine them being popular or available the next time you need one.
Old 03-21-2025, 08:56 AM   #20
Bored&Stroked
Question: It looks like a double-action pump with two diaphragms . . . one for fuel and the other for vacuum? Are those two hose connections for vacuum?
