Old 03-19-2025, 02:36 PM   #1
flathead4rd
flathead4rd's Avatar
Default Strange engine bolt. Where does it go?
I'm reassembling my engine 1950 8-CM and I found this bolt that is quite different than the rest. It's a 7/16 hex head about an inch about a quarter long, coarse thread. It has a hole drilled through the center threaded end and another through the top end of the threads. I assume it's used to lubricate some part. I tried to post a picture but no luck. Any thoughts?
flathead4rd is offline   Reply With Quote
Old 03-19-2025, 04:51 PM   #2
kurt v
Default Re: Strange engine bolt. Where does it go?
might be oil filter return line, on my 59ab it goes to a banjo fitting on the timing cover
kurt v is offline   Reply With Quote
Old 03-19-2025, 05:27 PM   #3
JayChicago
JayChicago's Avatar
https://thirdgenauto.com/product/193...ow-banjo-bolt/
Does not belong to his 1950. Or any post war car.
Old 03-20-2025, 12:54 AM   #4
fortyonerag
fortyonerag's Avatar
Banjo vacuum fitting?
fortyonerag is offline   Reply With Quote
Old 03-20-2025, 09:57 AM   #5
fordyford
fordyford's Avatar
The vacuum line to the distributor connection located just below the carburetor in the intake manifold.
fordyford is offline   Reply With Quote
Old 03-20-2025, 12:01 PM   #6
flathead4rd
Thanks to all who replied, especially the one with the picture. That's exactly what it looks like. My only other thought was, I replaced the oil pump idler gear and bushing and thought it might hold that assembly together to furnish oil to the bushing.
