Old 03-09-2025, 06:36 PM   #1
twostickmutt
Default 39 deluxe coupe rubber fender washers
I'm getting ready shortly to put the fenders back on the coupe front and rear. When I took it apart there was no rubber or steel fender washers on any fender. Question is do the rubber washers go between the fender and welting on every fender bolt including the grill bolts? Any help appreciated.
twostickmutt is offline   Reply With Quote
Old 03-09-2025, 08:04 PM   #2
Kube
Kube's Avatar
Default Re: 39 deluxe coupe rubber fender washers
Rubber washer against (inside) fender, then the flat washer, then the lock washer, all beneath the bolt head.
The only thing between the fender and body is the welt.
The photo I've attached is a '40 PU. However, the fasteners and their respective position is identical.
Old 03-10-2025, 04:05 AM   #3
twostickmutt
Perfect. Thank you...AGAIN...Kube !
Old 03-13-2025, 04:25 AM   #4
twostickmutt
Kube another quick question if I may. Are the rubber washers used where the fender bolts to the front inner fender and where the grill bolts to the front of the fender. Thanks again.
Old 03-13-2025, 08:18 AM   #5
Kube
Kube's Avatar
Yes, but they are a different diameter.
