Old 03-06-2025, 11:40 AM   #1
TomC750
TomC750's Avatar
Default '41 brake adjustment
Regarding the anchor adjustment on my '41 Merc, I seem to recall that the punch marks on the adjustments that take a1/4" wrench go towards each other. Mine are away from each other. My Motors manual does not have an illustration with the punch marks, but rather arrows pointing toward each other.
I am going through a total brake adjustment to get more brake pedal. Help me out here! What is correct?
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 03-06-2025, 11:57 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: '41 brake adjustment
Sorry I can’t remember which way the dots go without going out and looking but here’s how I adjust them. Thanks Dick Spadaro RIP.
Start with adjusting shoes to barely drag. Then the anchors. You need a helper to apply firm pressure to brake pedal. Loosen lock nut the rock flat adjuster back and forth you may notice it’s travel decreases as you do this. Park it in the middle of its travel and jam locknut being careful not to move adjuster. Now do the other anchor adjuster. When both are adjusted go back and re adjust shoes again so they just drag a little.
Now repeat process on same wheel. I do this 2-3 times on each wheel. It only takes a few minutes to do complete brake adjustment. Honestly I don’t care where the dots line up. Has always worked perfect for me giving a great pedal.
KiWinUS is online now   Reply With Quote
Old 03-06-2025, 07:10 PM   #3
TomC750
TomC750's Avatar
I should not have bothered to start the thread, as I answered my own question. The shape of the cam is such that there is only one high point per 360*. I do agree it is worthwhile to go through the adjustment process several times. And thanks for the response KiWinUS!
TomC750
1930 1 Ton White
Old 03-06-2025, 09:25 PM   #4
Zeke3
Zeke3's Avatar
It was good that you started the discussion because it may help the next guy.
Zeke3 is offline   Reply With Quote
