Old 02-25-2025, 08:58 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Serial number
Is there a serial number anywhere on a 1932 frame?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-25-2025, 09:11 PM   #2
DavidG
DavidG's Avatar
Default Re: Serial number
If originally a passenger car frame the engine number should be stamped on top of the left frame rail in three places. First is the full number just forward of the foot of the firewall. Second and third exclude the prefix and are hidden from view under the body at the B pillar and rear axle kickup.
If a commercial vehicle frame, only the full number near the left firewall foot is stamped on the frame.
Old 02-25-2025, 09:21 PM   #3
Charlie Stephens
You might find a little more serial number information here: http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
Charlie Stephens
Old 02-26-2025, 11:02 AM   #4
40larry
You call it the engine number but is it found on the engine?
40larry is offline   Reply With Quote
Old 02-26-2025, 11:16 AM   #5
tubman
tubman's Avatar
It is found on a pad on the transmission. Therefore it is not an engine number. Many, many transmission and engine changes may have taken place in the last 93 years, so there are a lot of mismatches out there.
Old 02-26-2025, 01:01 PM   #6
Newc
Newc's Avatar
Warning; all vin numbers are now in a Federal data base. duplicates have shown up [36 Ford]The trans mission vin numbers were originally matching the frame. Newc
Old 02-26-2025, 09:28 PM   #7
Chris Haynes
Actually 1932 models had no number on the engine. It was on the transmission.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-26-2025, 09:29 PM   #8
Chris Haynes
Can the frame number be seen with the fender removed?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-27-2025, 07:58 AM   #9
alchemy
alchemy's Avatar
It can be seen with the fender on even.
alchemy is offline   Reply With Quote
Old 02-28-2025, 12:42 PM   #10
51shoeboxer
VIN number, as in vehicle identification number number?
51shoeboxer is offline   Reply With Quote
Old 02-28-2025, 12:59 PM   #11
TJ
TJ's Avatar
Yes and it's the number used by the DMV
TJ is online now   Reply With Quote
Old 02-28-2025, 01:16 PM   #12
Charlie Stephens
Minor addition, the serial number for the 4 cylinder was on the flywheel housing and not the transmission. Of course it was also on the frame like the V8.
Charlie Stepehns
Old 02-28-2025, 08:10 PM   #13
TomC750
TomC750's Avatar
Quoted wrong party
TomC750 is offline   Reply With Quote
Old 02-28-2025, 08:11 PM   #14
TomC750
TomC750's Avatar
Point missed...
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
Old 03-29-2025, 09:28 PM   #15
Chris Haynes
Can someone show a picture of where this number is located? TIA
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-30-2025, 06:32 AM   #16
corvette8n
corvette8n's Avatar
From Vanpelts website drawing shows 38-39 but 32 should be the same. I used this to find the number on my ‘41. Mine was light but I cleaned the area and rubbed white chalk over the number.
Old 03-30-2025, 09:09 AM   #17
alchemy
alchemy's Avatar
The picture is kinda wrong for a 32. The front number is right at the firewall foot, the second number is under the B pillar area, and the third number is on the upswing of the rear frame, in front of axle centerline.
Old 03-30-2025, 01:00 PM   #18
petehoovie
petehoovie's Avatar
