Old 01-18-2025, 08:27 AM   #1
411Ton
Default 41 3/4 Ton truck front spring question
good morning folks. Any suggestions on how to remove the front spring from the frame? the bracket has a slot that you'd think would allow the spring pin to slide through, but that's not appearing to work. Are you supposed to get the pin out first, then the spring will drop? Confused....
411Ton is offline   Reply With Quote
Old 01-18-2025, 11:32 AM   #2
fordyford
fordyford's Avatar
Default Re: 41 3/4 Ton truck front spring question
You need to remove the nut on each end plus the washer that is in a recess.
fordyford is offline   Reply With Quote
Old 01-18-2025, 06:05 PM   #3
expavr
expavr's Avatar
Assuming your 3/4 T front spring assembly is similar to the 40 Tonner's assembly do the following:
1. Position a jack or blocks under the rear of the spring to prevent it from dropping to the floor. Remove all 4 nuts off the rear spring anchor. Remove the two dog bones that hold the the spring to the frame. Allow the spring to rotate down to the jack or blocks then lower it to the floor.
Photo 1
2. Loosen the two nuts holding the spring to the frame in the front taking care to support it while doing so. It will want to drop out of the slot.
Photo 2
The use of a rust penetrant or a nut splitter may be needed at either location to get the nuts off.
expavr is offline   Reply With Quote
Old 01-19-2025, 08:33 AM   #4
411Ton
Thanks! turns out the washers on the front bolts were stuck in place and rusted, didn't see they were there. Got those out and removed spring! Thanks!
