Old 08-01-2024, 10:26 AM   #1
Ohc Joe
Default 1936 sedan guage info swap
Ok on this 36 sedan
What 3 guage set up fits these holes without crazy modifications
Is there a kit available
Just want a simple set up nothing crazy
Ohc Joe is offline   Reply With Quote
Old 08-01-2024, 10:47 AM   #2
Kube
Kube's Avatar
Default Re: 1936 sedan guage info swap
Originally Posted by Ohc Joe View Post
Ok on this 36 sedan
Pretty sure any gauges from 36 through 39 will fit right in.
Kube is online now   Reply With Quote
Old 08-01-2024, 01:06 PM   #3
deuce lover
deuce lover's Avatar
Only 35,36.In 37 Ford went to 2 large gauges.
Old 08-01-2024, 02:15 PM   #4
Ohc Joe
I'm looking for some simple aftermarket type guages the original ones that were in here are kinda bad
Anyone try those dolphin brand guages by chance they seem simple enough
Old 08-01-2024, 05:35 PM   #5
rich b
rich b's Avatar
I used a SW speedometer, water temperature, and fuel level gauges along oil pressure and charge warning lights. Easy to fit without any crazy modifications; just a little welding & drilling. If you prefer all gauges, it isn't anymore work to do so; like the red dash I did for my buddies '33.
Old 08-01-2024, 07:01 PM   #6
ActionYobbo
ActionYobbo's Avatar
Take your original 4 gauges and disassemble it. Replace the 3 round gauges with modern 2” gauges temp & oil & volts then in the bottom where the thermometer was put your high beam light and turn signal flasher. It’s a relatively simple job. Don’t disassemble anything off the new gauges. You can have them rotated to work with the original cover plate or set the all horizontal and modify the cover plate.
I am building mind with fuel & oil & water for the round 3 and just an idiot light for the volts
So in the slot for the thermometer I will have green at the bottom for high beam then yellow in the middle for turn signal and red at the top for volts
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 08-01-2024, 07:54 PM   #7
Ohc Joe
Clean looking nice job
Old 08-01-2024, 08:15 PM   #8
oldbugger
oldbugger's Avatar
This may sound a bit out there, but I've been a VW guy for years so i looked for a later VW speedo it has gas gauge and lights for high beam oil press plus more. It fits the large hole. I put two after market volt and temp in the other holes. no cutting so if someone wants to go back to original no problem. No one has ever said anything against the look. just put a VDO gas gauge, works great
oldbugger is offline   Reply With Quote
Old 08-02-2024, 10:22 AM   #9
Ohc Joe
I have an extra vw guage from my 65
I'll pop it in there and take a look
Old 12-28-2024, 09:55 PM   #10
Ohc Joe
ok well i’m hoping tomorrow to grab the dash and start some guage looking up and getting this done
soooooo back to the top on this thread
hey anyone have any 36 guages all done and nice for sale maybe
thanks
Old 01-11-2025, 08:32 PM   #11
Ohc Joe
Well bought guages for a 57 chevy
Had to make the Speedometer hole a little bit bigger and that's it
Old 01-11-2025, 08:48 PM   #12
tubman
tubman's Avatar
Looks good; they match the radio dial well. Now you have to squeeze an oil pressure gauge and voltmeter (or ammeter) in there. I think they'll fit.
Old 01-12-2025, 09:46 AM   #13
Ohc Joe
Yeah I might hide them in the glove box this way I have a clean look
Old 01-14-2025, 10:58 AM   #14
Brendan
Brendan's Avatar
Just get a good set of stewart warner Mechanical gaudges, some vintage looking, and mount them under your dash, i have a oil pressure and temp on the left side of the steearing wheel
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-15-2025, 07:40 AM   #15
Ohc Joe
Ok
I'll look some up
Old 01-15-2025, 09:24 AM   #16
36coupe
36coupe's Avatar
https://www.lakeheaders.com/products...der-dash-panel
Another option
36coupe is offline   Reply With Quote
Old 01-15-2025, 10:16 PM   #17
Ohc Joe
Heck yeah that's bad...shoot
I was thinking about getting the ashtray too
Thanks for that link
Old 01-16-2025, 06:02 PM   #18
36coupe
36coupe's Avatar
I am thinking of a 3-3/8” S&W tach in place of the ashtray
