Old 11-30-2024, 05:19 PM   #1
Ohc Joe
Default 1936 sedan front springs
Anyone in Southern California have a lowered front spring setup for sale by chance 36 Ford Sedan stock setup before I try to put these shackle bushings in here I wouldn't mind lowering it two to four inches or so or where can I buy one thanks guys
Ohc Joe is offline   Reply With Quote
Old 11-30-2024, 05:48 PM   #2
TJ
TJ's Avatar
Default Re: 1936 sedan front springs
I would not go the "Mono Leaf" route. I saw a couple of them break. Try Pete and Jakes or Posies. Both may have a reversed eye main leaf. As an alternative you could take the stock spring to a good spring shop and have them de-arch the spring.
Old 11-30-2024, 07:53 PM   #3
Ohc Joe
Ok sounds good I'll look those guys up rather just get a complete unit ready to install if I can
Old 11-30-2024, 11:14 PM   #4
40cpe
40cpe's Avatar
https://www.speedwaymotors.com/Posie...-Drop,841.html
A posie spring might not give a 2" drop compared to the old, sagging spring.
Old 12-01-2024, 08:19 AM   #5
Ohc Joe
Awesome thanks the shake bushings need to be pressed in i assume on these bad boys
Old 12-01-2024, 10:45 AM   #6
rich b
rich b's Avatar
If the pin in the spring eye on the wishbone is good and you prefer stock style shackles a stock pin will work in an aftermarket spring.
We usually use modern shackles with poly bushings as the original stuff is worn out. Easier too; than dealing with oversize repop pins.
Old 12-01-2024, 08:43 PM   #7
Ohc Joe
The pin was completely worn out
Found a lower reverse new spring
It's on the way
How do these shakles install
Just a press I assume
Got a set from shoot the guy in LA Verne california awhile back ago the shakles kit
Ford store maybe
Old 12-02-2024, 11:26 AM   #8
TJ
TJ's Avatar
If it were me I would use the later type nylon bushing kit for the shackles. Much easier to install.
