Old 08-16-2023, 03:29 PM   #21
jim1932
jim1932's Avatar
Default Re: 32 Transmission Refresh
John, I have the book. Just miss read the catalog drawing. The 1st/Revers looks good.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 08-16-2023, 04:06 PM   #22
svm99
Originally Posted by 38 coupe View Post
Something damaged the teeth on that cluster gear. Did a previous repair already replace the 1st / reverse slider gear? If not the slider probably has matching damage.
In my experience it is not uncommon for the '32-'35 straight tooth cluster low gear to be galled and the slider gear to be usable after close inspection. I'd recommend replacing the cluster, they seem to be plentiful.
svm99 is offline   Reply With Quote
Old 08-16-2023, 05:13 PM   #23
petehoovie
petehoovie's Avatar
Old 08-16-2023, 06:36 PM   #24
DavidG
DavidG's Avatar
Lots of wear, but still usable, although I wouldn't (reuse it). That transmission seems to have had plenty of miles on it.
Old 08-17-2023, 08:09 AM   #25
jim1932
jim1932's Avatar
What would it cost to put a full set of the L-Z Gears in? I didn't see it as a set in the Van Pelt Catalog.
Old 08-13-2024, 06:22 AM   #26
Terry,OH
Terry,OH's Avatar
The reverse gear has slightly pointed gears on one side to help the slider enter the teeth. I too would replace it since they are rather common to obtain. Another point of heavy wear is the brass syncro rings which are part of the syncro hub. The hub has to be replaced to replace the rings.
Old 08-14-2024, 11:26 AM   #27
Bored&Stroked
Bored&Stroked's Avatar
In order to put the LZ gears in it, you'd be replacing the entire gear set - including the main shaft, synchro assembly, etc..
Also, the 32 shifter top will not work with the later gear sets (though some have cut/spliced and 'Frankensteined' a 32 top to work).
Most folks would put a 39 double-detent top on it. Since your case is for a 32 B motor, you'll not be able to just use a 39 transmission - you'd have to use the guts out of a 39, gears out of a LZ and a top from a 39.
Old 08-14-2024, 10:33 PM   #28
big deuce
big deuce's Avatar
Well, if your cluster gear is trashed, make a lamp out of it! This one is from a '34 3 speed.
big deuce is offline   Reply With Quote
Old 08-15-2024, 12:35 PM   #29
Bored&Stroked
I'd have lamps all over the house!
Old 08-15-2024, 04:35 PM   #30
DavidG
DavidG's Avatar
Me too!
