Old 06-09-2024, 09:39 PM   #1
Stoney Lonesome
Stoney Lonesome's Avatar
Default How to start a '28 Ford Model "A" the "Old-Time Way"
How to start a '28 Ford Model "A" the old time way.
From Stoney Lonesome Productions™ and Thanks for watching!
https://vimeo.com/435389638
short,comic,reel,WATCH...Old-Time,silent moving pictures:
https://vimeo.com/channels/stoneylonesome
Stoney Lonesome is offline   Reply With Quote
Old 06-10-2024, 07:21 AM   #2
old31
Default Re: How to start a '28 Ford Model "A" the "Old-Time Way"
I guess thats why my A wont start, I am not waring those fancy gloves.
old31 is offline   Reply With Quote
Old 06-10-2024, 08:39 AM   #3
Planojc
Planojc's Avatar
Nice truck.
Planojc is online now   Reply With Quote
Old 06-10-2024, 10:43 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
While I am not a proponent of using two hands, I do think it is worth mentioning that everyone should take note of this "Cranker's" hand position. If the engine were to 'kick', it should be able to release from his hands suddenly without jerking a thumb off.
One other thing that I learned the hard way that ultimately caused me to have Rotator Cuff surgery on my cranking arm is that the technique should not be to jerk the crank quickly thru rotation, but just to pull slowly and steady past the piston cycle. Since the cranking stroke is generally ¼ of a turn -or one piston compression cycle, then there is not any advantage to jerking it quickly. This is why even petite ladies back in the day were capable of hand-cranking a Model-A (or Model-T) engine.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-10-2024, 05:09 PM   #5
The Master Cylinder
The Master Cylinder's Avatar
Not sure what the choke did for him since he pull and released it??
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 06-19-2024, 01:12 PM   #6
rileyracing
rileyracing's Avatar
Sometimes starting the Ts at Greenfield Village I have to give the choke a 'blip' while it's cranking and then they will fire right up. It's usually when it's been cranked and started then died.
Very Respectfully,
jason
Barnstormers VSC- Celeritate Est Vita
Battery Fabrication Technologist- Ford Motor Company
Antique Vehicle Mechanic- Greenfield Village
Sometimes Docent - Ford Piquette Avenue Plant
Member #347- Early Ford Registry
rileyracing on the HAMB
rileyracing is offline   Reply With Quote
Old 06-21-2024, 08:20 AM   #7
shew01
shew01's Avatar
I’ve never tried hand cranking our car cold (I never really thought about that until now), but I usually have to blip the choke when using the electric starter when the car is cold. After the engine is warm, I can hand crank it without choking. Brent is right for our car. A slow crank of about a 1/4 rotation is usually all it takes.
We are blessed. Our car has always started easily.
Old 06-21-2024, 09:00 AM   #8
P.S.
This is how that is ACTUALLY done- https://youtu.be/8EWDRHC2dzg?feature=shared&t=127
2024-2025 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 06-21-2024, 09:59 AM   #9
Ruth
Very Respectfully,
jason
I would agree IF the ignition was on and the engine was turning over! All he did in the video is say "choke on" and pull and release.
Ruth
