Old 11-27-2023, 10:27 AM   #1
64DRK
Default Original 1932 pedal assembly
Hello all. I am desperately looking for a set of original 1932 pedals. If not the pedals at least the mounting bracket. I am mechanically restoring my father-in-law's 32 Sport Coupe and found that the previous "Mechanic/Restoration Shop" cut the mounting bracket and used a hydraulic master cylinder I am not familiar with. I'm not sure I will be able to rebuild this setup and want to make it easy for my kids should they need to rebuild it in the future. The K member is still intact and I would like to keep it that way.
ANY help is GREATLY appreciated!!!
DK
64DRK is offline   Reply With Quote
Old 11-27-2023, 10:48 AM   #2
svm99
Default Re: Original 1932 pedal assembly
Place an ad in the Early V8 wanted section
svm99 is offline   Reply With Quote
Old 11-27-2023, 10:53 AM   #3
64DRK
Will do
Old 11-27-2023, 11:29 AM   #4
Krylon32
Check with Andy on here. He had some a while ago?
Krylon32 is offline   Reply With Quote
Old 11-27-2023, 11:54 AM   #5
DavidG
DavidG's Avatar
Is your intention to revert to the original mechanical brakes?
Old 11-27-2023, 01:13 PM   #6
hb32
hb32's Avatar
Several in the early V8 classified section
hb32 is offline   Reply With Quote
Old 11-27-2023, 01:34 PM   #7
64DRK
Nickthebandit the site won't let me respond via PM
330 686 0224
Dave Kimberly
Old 11-27-2023, 01:34 PM   #8
64DRK
cant send email address either
Old 11-27-2023, 01:42 PM   #9
JayChicago
JayChicago's Avatar
Cuz you are a new member here. To make it harder for internet scammers to respond to ads, this site won't let you respond until you have made 10 posts. Just make a few more dummy posts, then you should be able to respond.
Old 11-27-2023, 01:43 PM   #10
Charlie Stephens
If you end up keeping hydraulics (depending on how/where the car is going to be used it might be a good idea) here is how I did it using original pedals. Too bad your previous owners didn't't do it this way.
PS, You should put your general location in your profile.
Charlie Stephens
Old 11-27-2023, 01:44 PM   #11
64DRK
xxx
Old 11-27-2023, 01:45 PM   #12
64DRK
zzz
Old 11-27-2023, 01:45 PM   #13
64DRK
rrr
Old 11-27-2023, 01:46 PM   #14
64DRK
ttt
Old 11-27-2023, 01:47 PM   #15
64DRK
sorry about the posts
Old 11-27-2023, 01:48 PM   #16
64DRK
eeee
Old 11-27-2023, 01:49 PM   #17
petehoovie
petehoovie's Avatar
Charlie Stephens
Old 11-27-2023, 02:05 PM   #18
64DRK
sss
Old 11-27-2023, 03:47 PM   #19
Karl Wescott
Karl Wescott's Avatar
IF you want to keep the existing hydraulic setup ("if it aint broke, dont fix it") you may be able to source the cylinders from a mainstream parts store IF there are casting numbers on said cylinders.
Karl Wescott is offline   Reply With Quote
