Old 08-29-2023, 12:32 PM   #1
coxswain98
Default Transmission roller bearing grease
I'm rebuilding my '39 transmission. Van Pelt book says nothing about packing the 7025 and 7065 roller bearings with grease, nor does Wired Custom's video. Should they be packed? If not why?
Thanks for your help
coxswain98 is offline   Reply With Quote
Old 08-29-2023, 03:30 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: Transmission roller bearing grease
Just done one of these ,transmissions don't use grease , a little oil on the needle rollers on assemble, before you put the lid on pour the oil over all the gears .Dont use sealed bearings on the rear ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-29-2023, 05:07 PM   #3
deuce_roadster
deuce_roadster's Avatar
Just use some of the gear oil you are going to put in the finished product.
As long as not dry, it will be fine..
Old 08-30-2023, 11:50 AM   #4
coxswain98
Thank you!
Old 08-30-2023, 12:59 PM   #5
35fordtn
35fordtn's Avatar
I have a clear ketchup bottle I bought at the Dollar Store full of 600W oil. I use it on all the bearings and thrust washers. Same with rear end bearings
Old 08-30-2023, 07:25 PM   #6
Bored&Stroked
Bored&Stroked's Avatar
I use engine assembly lube on most of these bearings (if they are new). It is thin enough to coat everything and MAYBE it helps during initial run-in (probably not - I'm just a bit anal!). LOL
Old 08-30-2023, 10:47 PM   #7
svm99
I do the same, I found the oil will mostly run to the bottom of the transmission if it sits awhile, I like all parts well coated before startup.
svm99 is offline   Reply With Quote
Old 08-31-2023, 08:54 AM   #8
cas3
I use "transmission assembly goo", yes thats the product name. Good for sticking the thrust washers on , and sticking on the roller bearings. especially on the later needle type bearings
Old 08-31-2023, 09:06 AM   #9
Bored&Stroked
That is a good point - if you happen to have a transmission with individual cluster needle bearings, you need something to hold them onto the cluster wall when you insert the main cluster shaft. I usually just use grease . . .
