Old 07-09-2023, 06:21 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default Starter cable routing on a 36 Tudor
Does the cable from the starter to the floor switch pass between the firewall and throttle linkage or below the throttle linkage? The way in the photo causes the pedal linkage to hang up on the cable.
Tim Carlig
dean333 is offline   Reply With Quote
Old 07-09-2023, 06:28 PM   #2
dean333
dean333's Avatar
Default Re: Starter cable routing on a 36 Tudor
After looking at the photo on p.112 of the 35-36 restoration manual and orienting it with my photo in relation to the sending unit, I need to flip the rubber bracket over. That will pull the cable away from the linkage.
Tim Carlig
Old 07-09-2023, 07:08 PM   #3
34fordy
34fordy's Avatar
I thought this was a 1/4" NPT opening into the oil galley?
34fordy is offline   Reply With Quote
Old 07-09-2023, 07:47 PM   #4
dean333
dean333's Avatar
The cable passes between the linkage and the engine. I flipped the rubber sleeve over so it holds the cable AWAY from the linkage.
Tim Carlig
Old 07-09-2023, 07:55 PM   #5
petehoovie
petehoovie's Avatar
Old 07-09-2023, 07:56 PM   #6
petehoovie
petehoovie's Avatar
Old 07-09-2023, 11:47 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
That's the way it should be attached.
John
Old 07-10-2023, 04:21 AM   #8
deuce lover
deuce lover's Avatar
Old 07-10-2023, 10:03 AM   #9
Planojc
Planojc's Avatar
I wish that some of my car problems could be resolved that easy.
Planojc is offline   Reply With Quote
