Old 08-20-2022, 07:27 PM   #1
decling
Default Original emblem repair or not
I have the V8 emblem for my 38 Ford truck and it has a crack in it. What are thoughts on this? Can it be repaired? Is it worth it cost wise repairing to keep an original or get a reproduction or leave it alone and don't worry about it?
decling is offline   Reply With Quote
Old 08-20-2022, 08:30 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Original emblem repair or not
Old 08-20-2022, 08:39 PM   #3
Lawson Cox
Lawson Cox's Avatar
If your truck is a driver I would use it as is. Those emblems are pot metal and difficult/expensive to repair. If your truck is restored, I'd consider using a reproduction one.
Old 08-20-2022, 09:06 PM   #4
ford38v8
ford38v8's Avatar
I had a restored center grill bar on my 38 DeLuxe, and paid a gentleman good money to trade for his original with original blue paint and pitted chrome. I consider original to be more desirable than the prettiest repop or restored piece.
Alan
ford38v8 is online now   Reply With Quote
Old 08-20-2022, 09:13 PM   #5
highbeams
highbeams's Avatar
I absolutely use original everything. If you desire new China on your V8, that's up to you
*We know what Henry would say.
highbeams is offline   Reply With Quote
Old 08-21-2022, 08:45 AM   #6
kurt v
There are some very high grade epoxies out there that will do the job, getting a small dab that you need will be the tough part. Price will be very high, see if you can find someone that works in factory maintenance may be able to find something.
kurt
kurt v is offline   Reply With Quote
Old 08-21-2022, 12:05 PM   #7
19Fordy
19Fordy's Avatar
It would be possible to "V-cut" a very slight bevel on the OEM piece crack, solder with special pot metal solder and then copper plate the entire emblem. Then follow up with chrome plating. Pot metal can be difficult to "save" as it has lots of internal pitting that you can't see. There are no guarantees.
Peruse these sites:
https://www.google.com/search?q=how+...hrome&ie=UTF-8
A few years ago I had Custom Metal Finishing in Hagerstown, IN repair and plate a pot metal steering wheel pieces and they turned out PERFECT. You might want to give them a call. Read this on HAMB first.
https://www.jalopyjournal.com/forum/...he-man.596824/
Old 08-21-2022, 03:18 PM   #8
B-O-B
B-O-B's Avatar
Just fill the back side V with J B Weld. Be sure to really clean the area first. Do not press too hard on the cracked area as it could break off.
B-O-B is offline   Reply With Quote
Old 08-21-2022, 08:01 PM   #9
39portlander
39portlander's Avatar
Good luck trying to find a reproduction. I would contact the fellas @ Vintage vehicles in Wautoma, will probably come back better than new. Yes it is always worth repairing/restoring an original piece.
Let us Know how you fix that. You could always just put in a plain center strip and tell every one it's a 39
39portlander is offline   Reply With Quote
