Old 08-08-2022, 06:21 PM   #1
V8guy
V8guy's Avatar
Default Removing steel sleeves
What is the easiest way to remove steel sleeves from a 99-T block, I recall reading .080 pistons can be installed once the sleeves are removed-?
V8guy is offline   Reply With Quote
Old 08-08-2022, 06:51 PM   #2
kurt v
Default Re: Removing steel sleeves
I just did that , ran 4 or 5 mig beads quickly inside the sleeves, took a sharp pin an drove it under the bottom edge enough to be able to lift the sleeve then used a heavy hammer and brass drift on the up turned edge and drove them out.
Took longer to type this than to do it.
kurt
kurt v is offline   Reply With Quote
Old 08-09-2022, 05:22 AM   #3
Ken/Alabama
Ken/Alabama's Avatar
The pistons you need are .083
Old 08-09-2022, 08:53 AM   #4
Tim Ayers
I wouldn't buy anything until the bores are checked out and the machinist knows how far out you need to go to get them round.
Old 08-09-2022, 11:41 AM   #5
deuce5wndw
deuce5wndw's Avatar
Excellent advice! I just took a set of the thin sleeves out and used a chisel designed for exhaust pipe removal. I modified it a little and didn't use the air hammer but a regular hammer for more control. It worked like a charm.
deuce5wndw is offline   Reply With Quote
