Old 07-30-2022, 10:36 AM   #1
carol ann
carol ann's Avatar
Post what spark plug wire brand/set is best?
I would like to replace the spark plug wires in my 40 ford sedan deluxe. It is still 6 volt positive ground, has a 59AB motor with crab type distributor and newly replaced champion H-12 plugs. I have no clue what wires to use and would appreciate a recommendation from the experts. Many thanks.
carol ann is offline   Reply With Quote
Old 07-30-2022, 11:20 AM   #2
tubman
tubman's Avatar
Default Re: what spark plug wire brand/set is best?
Does the car have a working radio?
Old 07-30-2022, 12:36 PM   #3
carol ann
carol ann's Avatar
No there is no radio
Old 07-30-2022, 01:47 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
If NO radio, then "Packard 440" wire for sure!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 07-30-2022, 02:12 PM   #5
tubman
tubman's Avatar
"Coop" - Will the Packard 440 wires fit through the stock looms? How true to original does the O/P want to be? I like Packard 440 and Rajah ends, but they sure aren't right on a properly restored vehicle.
I guess the O/P needs to clarify their original question. Are you willing to settle for a serviceable replacement or do you need to be "Concourse Correct"?
Old 07-30-2022, 04:59 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Black Packard 440 measures 7mm, and I believe the stock Ford flathead wires are also 7mm. The Packard wires MAY be harder to pull because of their RUBBER-LIKE finish, which may not slide very easily.
Coop
T5 W/TORQUE TUBE
Old 07-30-2022, 09:55 PM   #7
aussie merc
aussie merc's Avatar
stock coil ? and no radio depends if you want concorse look or not there's lots out there to choose from but stock ignitions arnt Known for high output [its adequate and works well ] but its not 40K +
aussie merc is offline   Reply With Quote
Old 07-30-2022, 11:37 PM   #8
ford38v8
ford38v8's Avatar
Coop
The Packard 440 rubber insulated wire will pull slicker than snot if lubricated with silicone, which will afford a substantial side benefit of preserving the rubber.
Alan
Old 07-30-2022, 11:41 PM   #9
Pete
You type faster than I do...lol
Old 07-30-2022, 11:41 PM   #10
ford38v8
ford38v8's Avatar
Champion H10 plugs were original equipment. Champion H10C plugs are available today from hardware stores, sold for use in lawnmowers.
Alan
Old 07-30-2022, 11:42 PM   #11
ford38v8
ford38v8's Avatar
That happens to me all the time!
Alan
Old 07-31-2022, 01:11 AM   #12
Tinker
Tinker's Avatar
If you have a stock car. Make sure they are copper. I'm not sure how much snot you like.
Old 07-31-2022, 07:21 AM   #13
Robert/Texas
Robert/Texas's Avatar
I really like the set I bought for my '34 about a year and a half ago from Third Gen. They look good and fit perfectly and the engine runs great with them.
Robert/Texas is offline   Reply With Quote
Old 07-31-2022, 07:28 AM   #14
Kube
Super Moderator
Kube's Avatar
With the 59ab, the "concourse correct" can't a concern.
Old 07-31-2022, 08:09 AM   #15
fortyonerag
fortyonerag's Avatar
Waa-aay back when I was green and simple I pulled wires on aeroplanes. We used to use talcum powder to lube wires.
Not sure what'd be better for plug wires tho'.
fortyonerag is offline   Reply With Quote
Old 07-31-2022, 08:31 AM   #16
carol ann
carol ann's Avatar
I appreciate this informative "discussion". I currently have what the previous owner installed and they appear to be "concourse correct" with cotton-braided plug wires and rajah terminals. I'm looking for best function over correctness as i would like to use this car as a daily driver for short trips. The rajah terminals with exposed metal concern me as i have gotten a hefty shock from them and the car runs a bit rough. I've not done the night time water spray test to see if there is any arcing. I've searched for the packard 440 set on line and I was able to find the DIY kits. does anyone know if they come pre-assembled with the right angle spark plug boot. thanks in advance.
Old 07-31-2022, 08:32 AM   #17
Robert/Texas
I used silicone spray to get them through the looms. It made that part of the job easy.
Old 07-31-2022, 09:24 AM   #18
tubman
tubman's Avatar
Right. I should have said "era correct".
Old 07-31-2022, 12:45 PM   #19
carol ann
carol ann's Avatar
No problem Tubman....I thought i was learning a new restoration term. thanks for clarifying.
Old 07-31-2022, 01:13 PM   #20
B-O-B
B-O-B's Avatar
I made my own. Purchased all my parts from The Brillman Company. Good people to deal with. They also carry electrical pieces for tractors.
B-O-B is offline   Reply With Quote
