Old 05-08-2022, 03:02 PM   #1
shew01
shew01's Avatar
Default Brake Squeal
When I apply the brakes, I’ve been hearing a pulsating squeal. Initially, I thought it was the drum rubbing against the backing plate on the passenger side rear wheel. So, I added an axle shim. That didn’t cure it. So, I added a second axle shim. That didn’t cure it either. So, I plan to remove the shims when I repack the rear wheel bearings in the next week or so.
I started repacking the front wheel bearings today, and I found some rust and some pitting in the brake drum.
Old 05-08-2022, 03:04 PM   #2
shew01
shew01's Avatar
Oops! That posted before I meant it to.
Can these drums be turned like the 1960’s and 1970’s drums could be turned?
Also, since there is rust, I’m thinking the brakes are not really engaging with the drum, correct?
Old 05-08-2022, 05:56 PM   #3
nkaminar
nkaminar's Avatar
Default Re: Brake Squeal
Yes, the rust would indicate that the brakes are not really working. You could try using some 80 grit sand paper to remove the rust from the drum and clean up the shoes. Model A drums are turned all the time and the shoes re arched to the drums. Just make sure they don't overdo it and make the drums too thin.
Are some kind of shields available to close up the holes in the drums and keep the water out?
Has the car been sitting for a while, where rust could have happened. It looks like the drums have a print of the shoes.
Old 05-08-2022, 06:15 PM   #4
shew01
shew01's Avatar
No, we drive it at least weekly. I was really surprised by the rust. It seems to stop well.
Old 05-08-2022, 06:20 PM   #5
shew01
shew01's Avatar
How does the re-arch process work? I’ve read about it in the past on this site, but search (via the TapaTalk app on my iPhone) isn’t returning anything useful.
Old 05-08-2022, 07:08 PM   #6
Bob C
Here's a video on shoe arcing. https://www.youtube.com/watch?v=H-ZF200ZSVs
Bob C is online now   Reply With Quote
Old 05-08-2022, 07:13 PM   #7
shew01
shew01's Avatar
Thanks!
Old 05-08-2022, 07:24 PM   #8
Patrick L.
Patrick L.'s Avatar
How did you end up with those drums ? I think they are pretty rare.
But I think they can be cleaned fairly easy. I think they may clean with elbow grease and sand paper, but, should be able to be turned to about .060" over.
Also as mentioned the shoes can be cleaned up with sand paper. You'll only sand off 10-20,000 miles [ smiley face].
To arch the shoes to the drum, remove them and put sand paper inside the drum and then rub the shoes against the drum/sand paper carefully. That'll get them pretty close to the drum shape.
It kinda sorta looks like they need a good adjustment. Or, it has pretty wet or rainy where you are.
Old 05-08-2022, 07:43 PM   #9
nkaminar
nkaminar's Avatar
The sanding technique to re arch the shoes works OK. It takes some time. It used to be that brake shops had re arching machines which basically sanded the shoes which were mounted on a holder that had a center pin and a radius adjusted equal to the drum radius. The machines have been scrapped and brake shops now just replace the shoes and drums as matched sets, if they work on drums at all. It is now difficult to find people who have the machine to re arch the shoes. Brent Terry has one in his shop in Tennessee, see https://www.model-a-ford.com/
I visited an old timer who told me that he just rode the brakes for a while to seat them in. That is one technique.
Old 05-08-2022, 08:34 PM   #10
Synchro909
Synchro909's Avatar
If those are steel drums, they are not easy to machine. They are prone to chatter which leaves a rough surface which will devour the linings. I'd do as suggested and clean them up and seat the linings in. For that, I spray a little paint from a rattle can on the inside of the drum, refit and by only applying the brakes by hand on the lever while I turn he drum, it is easy to see where they are contacting. A bit of filing with a coarse file (flat bastard) will remove material from where there is paint. I repeat a few times till I have a decent contact area, then I go for a drive with my foot on the brake to finish the seating process. It works every time.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 05-08-2022, 10:09 PM   #11
Herb Concord Ca
The drums shown in post #1 are late 31 cast iron drums. They are one-piece, hub and drum are made as one piece. Being cast iron they can be turned. Both my Model A's came with them. A few years ago I was able to buy a spare!
Herb Concord Ca is offline   Reply With Quote
Old 05-09-2022, 04:25 AM   #12
shew01
shew01's Avatar
They came on the car. I think they are called Rocky Mountain brake drums.
Since the squeal pulsates, I’m thinking the drums may have a slight warp. Turning them should clear that up, assuming a brake shop doesn’t get carried away removing material.
Old 05-09-2022, 05:15 AM   #13
Patrick L.
Patrick L.'s Avatar
Originally Posted by shew01 View Post
They came on the car. I think they are called Rocky Mountain brakes.
I didn't think there were many of those drums around. Yep, they are iron and can be turned. A shop that can turn them can also measure them.
Old 05-09-2022, 06:02 AM   #14
nkaminar
nkaminar's Avatar
The previous owner of my car replaced those type of open drums with the usual type which are not open. That is one option for you.
Old 05-09-2022, 12:41 PM   #15
Herb Concord Ca
Why would you replace cast iron drums with steel drums?
The only reason I can think of, if they have already been turned too far.
Old 05-09-2022, 01:33 PM   #16
1931 flamingo
1931 flamingo's Avatar
Sand the brake shoes, chamfer the front and rear trailing edges. Lightly sand the drums and you should be good to go. JMO
Paul in CT
Old 05-09-2022, 04:37 PM   #17
shew01
shew01's Avatar
I took the drums to a brake shop today and asked them to check for out of round and turn them the least amount possible. I’m hoping this will fix the pulsating squeal. We’ll see.
If it weren’t for the pulsating noise, I think I would have just sanded them and replaced them.
Old 05-09-2022, 05:07 PM   #18
jerrytocci
I like the squeal on my car. It's like an old movie sound effect. I have locked up all four wheels a few times in an emergency and the car stops well . If you look for problems you will be successful
jerrytocci is offline   Reply With Quote
Old 05-09-2022, 06:45 PM   #19
nkaminar
nkaminar's Avatar
Herb, He replaced the open drums with the usual cast iron drums.
Old 05-09-2022, 10:09 PM   #20
larrys40
As was said in post 11 they are late 31 cast iron drums. They are the drum of choice if someone has them as long as they are not too much oversized.
I can tell by your brake impression the car has sat at some point . I would suggest turning the drums just enough to clean them up to round and replace the linings with molded lining. You can arc and fit the shoes for best fit. Make sure your roller tracks and all are in excellent shape. Use a brake centering gauge to make sure all is in order with shoe contact too, bottom , center.
If you have the rear cast iron late 31 ( they are closed of course) they are excellent drums too. Typically if you have your front wheel tight and it fits the drums well the front brakes do NOT get wet. I am running them on one of my cars and have for 40 years and I do not have a problem with my brakes getting wet outside of normal rain.
Done well Model A brakes can screech to a stop, I have literally smoked the tires on my 30 tudor on a hard test stop. My 160b can also screech to a stop .
Larry Shepard
larrys40 is offline   Reply With Quote
