Good evening everyone.
Removed the valve cover off of my 29, only to find cracks around the area where the bolt is threaded into the cover at the oil return location. The problem is that who ever did previous work on it over tightened that bolt and now it has cracks in it. It's not broke out, but I don't really want to put it back together like that. If it were to breakout while on the road, it would pump the oil out. My question here is, has anyone had to deal with something like this, or if I could I would buy a new one, but I cant seem to find any new ones Thanks in advance!! |
Put an ad in the swap meet. There should be plenty of them around. Measure the location of oil return hole, so you get the correct one.
Bert’s in Denver would also have them. |
Used won't be a problem. Its probably one of the easiest pieces of the engine to find.
#4 | |
I have one if you would like it Sent from my iPhone using Tapatalk |
#5 | |
www.whidbeymodelaclub.com |
Bob Bidonde |
#7 | |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
We do the crack repair on those covers as finding a crack free one is nearly impossible after 92 years. http://www.jandm-machine.com/crack_repair.html |
#8 | |
#9 | |
Because every man and his dog buys a full flow oil filter kit and this part is within the kit? |
Weld or braze it up, put it back on but don't overtighten it.
I have the same issue, could not find another, put it back on but tightened the bolt just to seal, been four years and no problems, not a drop of leakage.
I'm not going to worry about it at this time.
I agree I have 6 not cracked in the shop!
#13 |
#14 |
Have good ones, but I am out west. Must be the water.
#15 |
Thanks for all the help guys!! At least I know that all hope is not lost!! I do appreciate the help.
#16 |
there are two styles early and late. make sure you order the correct one or you will need a different drain tube.
if you want new you can get a new aluminum one that has a filter adapter on it.
old ugly my mom would have told me. "these things are here to test us" |
#17 |
if you were totally stuck you could probably make an insert that fits into the cover from the back that will accommodate the attaching bolt.
i am sure you will find one, i have 3 old style ones here i will send you one free . you pay for the shipping cost. probably $25 to ship???
