Old 09-01-2021, 02:03 PM   #1
flybob08
Default 28' Roadster pickup tailgate
I have a 28 Roadster pick-up and while the brackets look right on the tailgate, the hook from the chain cannot keep the tailgate locked into position. Is something mounted incorrectly or am I missing a piece?
Any thoughts / help would be appreciated.
Bob
flybob08 is offline   Reply With Quote
Old 09-01-2021, 02:08 PM   #2
31Tudor
31Tudor's Avatar
Default Re: 28' Roadster pickup tailgate
Instead of hooking it over the top, come up from the bottom, and then hook over. That will keep them in place going down the road.
31Tudor is offline   Reply With Quote
Old 09-01-2021, 02:38 PM   #3
flybob08
The problem is that the holes on the tailgate and the holes on the body do not line up to get the hook through, even though both hook points appear to be mounted where they belong, but maybe not
Thanks
Old 09-01-2021, 02:50 PM   #4
Keith True
Keith True's Avatar
It looks right,but as 31 says the hook needs to come up through the bottom.Also,the union you are using for the link is really too big.The hook does not go through both of those holes.You have it hooked right,but just with one wrong part.
Keith True is online now   Reply With Quote
Old 09-01-2021, 02:53 PM   #5
Bob C
The hook doesn't go through both holes.
Bob C is online now   Reply With Quote
Old 09-01-2021, 03:05 PM   #6
john charlton
john charlton's Avatar
31 tudor is quite correct the pointed end of the hook must face back when you hook it not to the front as you have it . Just that simple .
John in Suffolk County England .
Old 09-01-2021, 03:24 PM   #7
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Here is my 31wide bed ccpu. Hook from under, otherwise the hook likes to jump out.
Ivan in southeast va. is offline   Reply With Quote
Old 09-01-2021, 03:34 PM   #8
wrndln
I am attaching a good picture of how the tailgate is fastened to the box. Note the steel loop that goes over the tailgate bracket. It appears you have some kind of aftermarket bracket instead of the original steel loop bracket Ford used.
Rusty Nelson
Old 09-01-2021, 04:26 PM   #9
Dan Partain
Dan Partain's Avatar
Here's a photo of an original tailgate chain assembly with the large link.
You're tailgate has a hardware store chain repair link in place of the welded original link.
Dan Partain is offline   Reply With Quote
Old 09-01-2021, 04:47 PM   #10
flybob08
Many Thanks - Pictures are worth 1,000 words and hours of trying to figure out why it isn't doing what I thought it was supposed to do
Old 09-01-2021, 05:19 PM   #11
Step-down
Step-down's Avatar
Photos attached
File Type: jpeg 5A966627-08EE-49C6-9D63-F9F9C8E2DA3F.jpeg (69.4 KB, 43 views)
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
