OK, I was under my 1928 coupe and noticed that the 2 smallest leaf springs are mounted on the bottom [under the main spring]. Does anyone know why someone would do this?
Only reason I can think is someone was trying to adjust the ride, so they swapped the top leaves to the bottom to reduce the effective springiness while retaining the right number of leaves for the assembly hardware.
Suspect the ride height was also reduced.
To use them as spacers
The top leaf, front AND rear, are beveled too fit the cross member correctly..!
Something to think about.. |
