The Ford Barn
-   -   Rear spring (https://www.fordbarn.com/forum/showthread.php?t=297864)
gmc4hire 04-27-2021 01:16 PM
Rear spring
OK, I was under my 1928 coupe and noticed that the 2 smallest leaf springs are mounted on the bottom [under the main spring]. Does anyone know why someone would do this?:confused:
alexiskai 04-27-2021 01:38 PM
Re: Rear spring
Only reason I can think is someone was trying to adjust the ride, so they swapped the top leaves to the bottom to reduce the effective springiness while retaining the right number of leaves for the assembly hardware.
Mulletwagon 04-27-2021 01:45 PM
Re: Rear spring
Suspect the ride height was also reduced.
Kurt in NJ 04-27-2021 03:06 PM
Re: Rear spring
To use them as spacers
d.j. moordigian 04-27-2021 03:34 PM
Re: Rear spring
The top leaf, front AND rear, are beveled too fit the cross member correctly..!
Something to think about..
gmc4hire 04-28-2021 09:34 PM
Re: Rear spring
Update, the top leaf has the "Ford" logo stamped on it, that was cool to see. It also is beveled as stated earlier.
