Old 03-17-2021, 01:29 PM   #1
bob p
Default Vibrating,
My friend has a 1929 2dr. While accelerating over 30mph it starts to vibrate and quits when you let up on the gas, Any thoughts?
bob p is offline   Reply With Quote
Old 03-17-2021, 02:12 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Vibrating,
Set your tow-in.
Old 03-17-2021, 07:21 PM   #3
Patrick L.
Patrick L.'s Avatar
Where do you feel it ? Thru the steering wheel or seat of your pants ?
How does it act if you leave the throttle at the position and push in the clutch pedal ?
Old 03-18-2021, 10:54 AM   #4
katy
katy's Avatar
Motor mounts?
Old 03-18-2021, 11:55 AM   #5
jetmek
Motor mounts or drive shaft
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 03-18-2021, 12:28 PM   #6
Will N
Will N's Avatar
U joint?
Will N is offline   Reply With Quote
Old 03-18-2021, 01:22 PM   #7
bob p
Hi, The vibration quits when you push the clutch in, Thanks.
Old 03-18-2021, 03:58 PM   #8
woofa.express
woofa.express's Avatar
My Tourer was the same. It was like the tingling one gets in one's hands from perhaps a lawn mower or power tool that maybe out of balance. I replaced the rear engine mounts with floater mounts. The problem solved.
Whilst that remedy addressed my problem it may not, of course, solve your friends.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
