Old 08-08-2020, 07:48 AM   #21
Juggler
Juggler's Avatar
Default Re: Best in class head
Originally Posted by kenparker View Post
BRIERLY head. didnt know there wa one. Tell me more or where on facebook do I look. ken
Here's mine
fullsizeoutput_64
fullsizeoutput_66
Juggler is offline   Reply With Quote
Old 08-08-2020, 04:25 PM   #22
Jim Brierley
John & Juggler, thanks. Anyone can e-mail me at [email protected] for more info.
Old 08-08-2020, 11:55 PM   #23
M2M
M2M's Avatar
Originally Posted by M2M View Post
7 to 1 So if you stick this head on a bone stock 40hp engine, how much of a boost in hp would you get?
Originally Posted by Jack Shaft View Post
Boosting power and efficiency is a sum of all parts,the head alone will help but to gain maximum return matching carburetor flow rate to engine flow rate,increasing cam lift and duration,providing engine rpm controlled timing and increasing exhaust flow along with the compression increase from the head yields results..and yes,RED is a proven secret of speed,it goes faster,runs cooler and gets more chicks..
Give me a number when adding your head alone? A police head gives 20% increase I believe and they are only 5.5 compression.
M2M is offline   Reply With Quote
Old 08-08-2020, 11:59 PM   #24
M2M
M2M's Avatar
Originally Posted by Jim Brierley View Post
Adding compression and a bigger carb are the quickest and easiest ways to more power. Hard to beat a Winfield, unless it is a BRIERLEY head. I'd post a pic but posting here is too complicated for my old brain. Facebook is much easier. A Stromberg 81 is much better than a stock carb, a 97 is even better.
Geez Jim Brierley...now you tell us you make a head !? Speak up man !
