Old 04-13-2020, 04:48 PM   #21
deuce_roadster
deuce_roadster's Avatar
Default Re: 1940 Ford Deluxe X member sheet metal original thickness
For what it is worth, I crawled under my 40 wagon and felt up above where the engine stay rod bolts are and there was no reinforcing doubler plate, checked my coupe and there was. My 40 wagon is a fairly late production 18 585xxxx. Maybe other 40 wagon owners can check theirs. Interesting.
Old 04-13-2020, 07:57 PM   #22
Kube
Super Moderator
Kube's Avatar
That's odd & interesting indeed. That really makes me wonder if the wagon frames were leftover??? I find that hard to believe but who knows.
I didn't spend much time researching the wagons and now, in a case like this, I wish I had.
Old 04-13-2020, 11:51 PM   #23
40larry
Also it would be interesting if any other owners of a 1940 pickup or convertible could check for the doubler plate and take a measurement of the x-member thickness to add to our knowledge base.
40larry
40larry is offline   Reply With Quote
Old 03-28-2021, 10:10 AM   #24
svm99
Originally Posted by Kube View Post
Mart, Your memory is intact! The convertible utilized a piar of bolt in braces very near the cowl "feet". I have attached a photo of a pair I'd restored for the last '40 convertible I'd done.
The convertible frame rails were intended to be .010" thicker than the closed car frame rails.
I’m working with my brother on a ‘39 station wagon project and are missing one of the frame braces posted above. If anyone has a usable brace we’d be interested. I know the classifieds are the right place for a want ad, just don’t have a good pic or a part number yet. Thank you for all of your research, has been very helpful so far.
svm99 is offline   Reply With Quote
Old 03-28-2021, 12:10 PM   #25
Kube
Super Moderator
Kube's Avatar
SVM99,
Here's two photos of the braces you desire. They were reproduced many years ago so hopefully there's a pair out there for you just waiting to be found.
The repops did require a bit of bending and twisting to make fit properly but nothing too serious.
Old 03-28-2021, 02:06 PM   #26
svm99
SVM99,
Thank you, we’ll be on the hunt!
Old 03-28-2021, 06:57 PM   #27
swoopNZ
MEMBER EMERITUS
I have a very original '40 Pickup that came from Illinois.
Chassis # 18539 9xxx which would indicate a fairly early example.
It does not have the reinforcing plate.
swoopNZ is offline   Reply With Quote
Old 02-16-2023, 03:03 PM   #28
jackstevens
Any suggestions for getting 40 Ford 1/2 T PU X member support brace, passenger side Part # 78-4048 or 49? Don't know if passenger side is 5048 or 8049). Drake no longer makes them.
Thanks, Jack
jackstevens is offline   Reply With Quote
Old 02-16-2023, 03:37 PM   #29
Zeke3
Zeke3's Avatar
Check with Joe's Antique Auto Parts, their part numbers, PC-80 and PC-81.
Zeke3 is offline   Reply With Quote
