Old 08-02-2019, 12:38 AM   #1
31Abone
31Abone's Avatar
Default torque tube lenght 32 car v8 vs. 32 B PU
Is drive shaft and torque tube same lenght on 32 v8 car and 32 4 cyl pickup ??? someone said they different lenght..??? tnx much
31Abone is offline   Reply With Quote
Old 08-02-2019, 01:07 AM   #2
deuce lover
deuce lover's Avatar
Default Re: torque tube lenght 32 car v8 vs. 32 B PU
Same.Its the 33-34 that is different from V8 to 4cyl
Old 08-02-2019, 08:08 AM   #3
DavidG
DavidG's Avatar
Perhaps that someone was referring to the late 18-prefix axle assembly compared with the rest-of-the-model-year B-prefix axle assembly. There are small differences in the torque tube and drive shaft lengths in the two axles, but overall, both axles are the same length from the front of the drive shaft to the center line of the rear axle shafts and therefore both interchangeable and used with both fours and V8s in production.
Old 08-02-2019, 10:03 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
David has a good point: The earlier 32 'Model A' style rear ends have a different torque tube and drive shaft. The design as well as lengths are different - due to the different types of rear ends in the cars - but the overall length of the entire "assembly" from transmission back - is the same.
