Old 09-22-2018, 07:07 AM   #1
FrankWest
FrankWest's Avatar
Default now to prime a model b oil pump
How do you prime a model B oil pump?
FrankWest is offline   Reply With Quote
Old 09-22-2018, 11:32 AM   #2
Ed Pitts
Ed Pitts's Avatar
Default Re: now to prime a model b oil pump
Pour a quart of oil down the distributor hole in the head.
Ed Pitts is offline   Reply With Quote
Old 09-22-2018, 12:20 PM   #3
FrankWest
FrankWest's Avatar
Thanks....For your help, but in second thought would be already be primed because on the model B as on the model A the pump intake screen already sits in the oil in the plan?
Old 09-22-2018, 12:40 PM   #4
RalphM
RalphM's Avatar
I always prime / fill the pump with assembly lube if I can’t prime with a drill.
RalphM is offline   Reply With Quote
Old 09-22-2018, 03:01 PM   #5
DavidG
DavidG's Avatar
While it is good idea to prime a V8 pump except perhaps the first design used on the earliest '32s, the very nature of a Model A or B oil pump (and the first '32 V8 pump version) is that they are self priming by virtue of their open bottom being immersed in four plus inches of oil.
Old 09-22-2018, 03:55 PM   #6
FrankWest
FrankWest's Avatar
The more I learn about the ford model B and model A engine..I am amazed at the beauty of them, design and simplicity of operation. Designed by real genius
so that almost anyone can operate.
Old 09-23-2018, 05:16 PM   #7
PeteVS
PeteVS's Avatar
Can the distributor be removed and the oil pump be spun like in some other V8's?
Old 09-23-2018, 06:46 PM   #8
grumppyoldman
grumppyoldman's Avatar
No the oil pump is driven from the back of the cam, maybe pour some oil down the breather tube might get some oil in that way. Like other's have said it is covered in oil in the pan and should not need priming. Al
grumppyoldman is offline   Reply With Quote
Old 09-23-2018, 06:50 PM   #9
DavidG
DavidG's Avatar
With respect, this is a four-cylinder pump he is asking about which is driven off the center of the camshaft, not off the rear. The breather tube/oil filler tube is on the other side of the engine and not aligned with the pump.
