Old 04-05-2018, 09:34 PM   #21
JSeery
JSeery's Avatar
Default Re: 51 F2 226 Project
That is just the typical setup same as a later 8ba engine.
Old 04-06-2018, 01:21 AM   #22
flatheadmurre
flatheadmurre's Avatar
Ok itīs the keepers that is fighting you.
Tap the "sleeve" so it letīs go of the keepers.
Old 04-06-2018, 06:44 AM   #23
glennsanders
glennsanders's Avatar
I just picked up 2 f-2 if u need parts give a pm.I also have running 6 cyl in St Louis ,new radiator, muffler starter, generator ete.
glennsanders is offline   Reply With Quote
Old 04-06-2018, 09:58 AM   #24
FirstGenF2
FirstGenF2's Avatar
Tapping the sleve does nothing, i cut one off with a dremel and it was crimped at the bottom, i assume thats not normal. If neccessary i will do that to remove all of them.
51' F2
45' CJ2a
FirstGenF2 is offline   Reply With Quote
Old 04-06-2018, 02:14 PM   #25
FirstGenF2
FirstGenF2's Avatar
You wouldnt happen to have a bed, subframe and frame mounts?
51' F2
45' CJ2a
Old 04-07-2018, 11:17 AM   #26
FirstGenF2
FirstGenF2's Avatar
i removed 2 more valves and the sleeves were hand crimped on and are oblong this isnt normal is it?
51' F2
45' CJ2a
Old 04-07-2018, 12:02 PM   #27
JSeery
JSeery's Avatar
No, it is not. I often just cut the valve and spring assemble to get them out. If you are not going to be reusing any of the parts (which I don't) there is not much reason to spend the effort to remove them the normal way.
Old 04-07-2018, 12:25 PM   #28
FirstGenF2
FirstGenF2's Avatar
Ok, yeah I'm going to have to do that for all the valves if they are all crimped like this.
51' F2
45' CJ2a
Old 04-08-2018, 10:31 AM   #29
FirstGenF2
FirstGenF2's Avatar
I pulled the engine so that I could strip it better, how do you remove the fly wheel to put it on a stand?
51' F2
45' CJ2a
Old 04-08-2018, 10:34 AM   #30
flatheadmurre
Unbolt and tap gently from backside until it lets go.
Old 04-18-2018, 07:10 PM   #31
FirstGenF2
FirstGenF2's Avatar
Ok, I've got the engine out and disassembled less the valves, front axle removed and just got a sandblaster to clean the frame and prep for paint. Removing the rear axle is giving me a bit of trouble, but it shouldn't be too difficult to remove the pins. Would it possibly be easier to flip the frame to pound the front spring pins?
51' F2
45' CJ2a
Old 05-22-2018, 09:49 PM   #32
FirstGenF2
FirstGenF2's Avatar
so I'm on summer break now and have spent the last couple days cleaning and painting the frame. Any tips for removing the rear spring mounting pins?
51' F2
45' CJ2a
Old 05-23-2018, 09:11 AM   #33
Ross F-1
Ross F-1's Avatar
Do you have the bed off? On F-1's at least there is no access to the front pins on the rear springs from the inside of the frame, there is a brace right in front of them. So make a puller by re-threading a bolt to 1/8-NPT so it will screw into the hole for the zerk fittings. See below. Use sockets that will clear the pin as it is drawn out.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-23-2018, 12:10 PM   #34
FirstGenF2
FirstGenF2's Avatar
Its a bare frame with only the rear spring mounted, and its the front pins im having trouble with. Ok that makes sense il get thread rod and try that
51' F2
45' CJ2a
