Old 02-14-2011, 03:55 PM   #1
rags999
Default Master Cylinder
Is there a duel master cylinder that would work with the standard brakes on my 50 Ford pickup?
rags999 is offline   Reply With Quote
Old 02-14-2011, 04:13 PM   #2
flathead4rd
flathead4rd's Avatar
Default Re: Master Cylinder
I think JAMCO has a conversion kit in both power and standard brake systems.
flathead4rd is offline   Reply With Quote
Old 02-14-2011, 07:04 PM   #3
Karl Wolf
Karl Wolf's Avatar
Early Mustang dual, (I think the 65-6 may have been singles) so around 68-70... This is just a memory of some one elses deal... Karl
Karl Wolf is offline   Reply With Quote
Old 02-15-2011, 05:59 PM   #4
Ronnie
Ronnie's Avatar
Some good info here
http://www.performanceonline.com/194...0-TRUCK-c-360/
enjoy
Ronnie is offline   Reply With Quote
Old 02-15-2011, 07:34 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Mid to late 60's GM for drum/drum. It has the residual valves built in.
I had this setup on my '51 Merc. which has the same size brakes as the '50 Ford pickup. The cover may be different than the one shown.
Old 02-15-2011, 07:55 PM   #6
41ford1
41ford1's Avatar
Use something like the Napaonline site to find a dual M/C that has the same piston diamter as the stock unit. I am running a '68-'70 Chevy/GMC C20 unit in mine.
41ford1 is offline   Reply With Quote
Old 02-15-2011, 08:20 PM   #7
Kahuna
Kahuna's Avatar
Karl is correct: 67-68 Ford Mustang is a good fit.
Kahuna is offline   Reply With Quote
Old 02-16-2011, 08:11 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
Either the Mustang or the GM will work. All depends where you want the brake line fittings to be. Mustang towards the center of vehicle, GM towards the frame rail. You will also need an adapter plate. such as sold by ECI.
http://www.ecihotrodbrakes.com/ford_...r_systems.html
Old 02-16-2011, 10:37 AM   #9
bobj49f2
bobj49f2's Avatar
Changing to a dual master cylinder seems like a fairly easy thing to do on our trucks but the one problem I see arise from doing this is accessibility to fill the master cylinder. The stock unit is a pain to get to, having to worry about something falling into it while removing the cap, checking the level and filling. The updated master cylinder will have a larger cover which will be more difficult to access through the round hole. I'm currently working a '37 Buick and am installing a dual reservoir master cylinder but on the Buick it is a lot more difficult because of the construction of the frame. I am going with a remote fill system with remote reservoirs mounted on the firewall. Just a thought for you guys to consider.
bobj49f2 is offline   Reply With Quote
Old 03-03-2011, 06:30 PM   #10
terhotrod
I'm building a 51 Ford pickup....I'm using a 1982 Ford F350 disc drum 1.062" master cylinder. How do you tell which port on the master cylinder is for the front disc and which is for the read drums? Can it be determined by the port thread size? ANY HELP
terhotrod is offline   Reply With Quote
Old 03-03-2011, 06:38 PM   #11
55 dude
55 dude's Avatar
everyone always seems to concerned about being able to access to new m/c but really how often do you even think about it? unless it fails it's normally forgotten. drilling a small hole in the floorboard that a 1/4" tube can fit through is all you really need to fill m/c with.
55 dude is offline   Reply With Quote
Old 03-03-2011, 09:10 PM   #12
V8 Bob
V8 Bob's Avatar
On all-metal disc/drum masters with full size caps, the larger (obvious) chamber always goes to the fronts.
Old 03-03-2011, 09:17 PM   #13
paul2748
paul2748's Avatar
The larger reservoir is for the front. Are you running 4 wheel drums or disc/drums?
I'm assuming that the master you have is a disc/drum master. Yes? If so and you are going to run disc/drums, you will need two residual pressure valves (10 lbs for the drums, 2 lbs for the discs, plus a proportioning valve.
If you are running all drums, then you will need two 10 lb residual pressure valves, probably not a proportioning valve (again assuming a disc/drum master.)
Old 03-03-2011, 10:00 PM   #14
FRANK PKNY
FRANK PKNY's Avatar
To fill on my 39 pu with a duel set up I just made a 3" hole in the floor board and cap it with a large rubber seal to fill the hole . All you need to do to inspect and fill if needed is pull up the floor matt.
FRANK PKNY is offline   Reply With Quote
Old 03-04-2011, 08:44 AM   #15
terhotrod
Yes, I'm running disc and drums. Forgot to mention that I'm running firewall mount also, so probably won't need the residual valves. Isn't that more for master cylinders that are low and possibly under the caliper level? Or should I run residuals anyway? I've always thought that the large chamber on the master cylinder was for the disc brakes, but was recently told by someone that I was mistaken. Needed to confirm....Thanks
Old 03-04-2011, 09:52 AM   #16
V8 Bob
V8 Bob's Avatar
You won't need, or want, a residual to the front discs with the firewall mounted master cylinder, but the rear drums should have one, either internal in the master or a 10 lb inline external.
Whoever that someone is who "told" you is wrong-the larger chamber ALWAYS goes to the fronts, drum or disc.
Old 03-04-2011, 01:27 PM   #17
terhotrod
Thank You V8 Bob, I appreciate all of you guys and your help....terhotrod
