Master Cylinder Is there a duel master cylinder that would work with the standard brakes on my 50 Ford pickup?
Re: Master Cylinder I think JAMCO has a conversion kit in both power and standard brake systems.
Re: Master Cylinder Early Mustang dual, (I think the 65-6 may have been singles) so around 68-70... This is just a memory of some one elses deal... Karl
Re: Master Cylinder |
Re: Master Cylinder Quote:
I had this setup on my '51 Merc. which has the same size brakes as the '50 Ford pickup. The cover may be different than the one shown. http://i11.photobucket.com/albums/a1...0Merc/mstr.jpg |
Re: Master Cylinder Use something like the Napaonline site to find a dual M/C that has the same piston diamter as the stock unit. I am running a '68-'70 Chevy/GMC C20 unit in mine.
Re: Master Cylinder Karl is correct: 67-68 Ford Mustang is a good fit.
Re: Master Cylinder Either the Mustang or the GM will work. All depends where you want the brake line fittings to be. Mustang towards the center of vehicle, GM towards the frame rail. You will also need an adapter plate. such as sold by ECI.
http://www.ecihotrodbrakes.com/ford_...r_systems.html |
Re: Master Cylinder Changing to a dual master cylinder seems like a fairly easy thing to do on our trucks but the one problem I see arise from doing this is accessibility to fill the master cylinder. The stock unit is a pain to get to, having to worry about something falling into it while removing the cap, checking the level and filling. The updated master cylinder will have a larger cover which will be more difficult to access through the round hole. I'm currently working a '37 Buick and am installing a dual reservoir master cylinder but on the Buick it is a lot more difficult because of the construction of the frame. I am going with a remote fill system with remote reservoirs mounted on the firewall. Just a thought for you guys to consider.
Re: Master Cylinder I'm building a 51 Ford pickup....I'm using a 1982 Ford F350 disc drum 1.062" master cylinder. How do you tell which port on the master cylinder is for the front disc and which is for the read drums? Can it be determined by the port thread size? ANY HELP
Re: Master Cylinder everyone always seems to concerned about being able to access to new m/c but really how often do you even think about it? unless it fails it's normally forgotten. drilling a small hole in the floorboard that a 1/4" tube can fit through is all you really need to fill m/c with.
I'm assuming that the master you have is a disc/drum master. Yes? If so and you are going to run disc/drums, you will need two residual pressure valves (10 lbs for the drums, 2 lbs for the discs, plus a proportioning valve. If you are running all drums, then you will need two 10 lb residual pressure valves, probably not a proportioning valve (again assuming a disc/drum master.) |
Re: Master Cylinder To fill on my 39 pu with a duel set up I just made a 3" hole in the floor board and cap it with a large rubber seal to fill the hole . All you need to do to inspect and fill if needed is pull up the floor matt.
Whoever that someone is who "told" you is wrong-the larger chamber ALWAYS goes to the fronts, drum or disc. |
Re: Master Cylinder Thank You V8 Bob, I appreciate all of you guys and your help....terhotrod
