Old 02-07-2018, 10:26 PM   #1
Solo_909
Default 35 ford rear swap?
I ran a search and couldn’t find much on common rear axles used for swapping out the banjo rear end. My banjo is leaking pretty bad so time for an upgrade.
Side question, can the rear wishbone be used on the newer axle? I’m not really interested in running parralle leafs.
Thanks!
Solo_909 is offline   Reply With Quote
Old 02-07-2018, 10:58 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 35 ford rear swap?
Thanks!
ANY complete banjo rear end, spring and torque tube included, will virtually bolt-in to your '35. All of the important dimensions are the same, '35-'40.
Your rear wishbones will only bolt-up to '35 and '36 axle bells. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-07-2018, 11:07 PM   #3
Solo_909
I apologies, I should have been more clear. I’m looking to swap in someone more modern like a Ford Explorer rear end or something easily available at the junk yard.
Old 02-07-2018, 11:14 PM   #4
RalphM
RalphM's Avatar
Check on the H.A.M.B., you’ll find alit more info. Although I believe an early 9” from 57-59 will fit under the fenders, but hardly a bolt on job.
RalphM is offline   Reply With Quote
Old 02-07-2018, 11:20 PM   #5
johndee138
johndee138's Avatar
replace your seals and maybe the R&P
johndee138 is offline   Reply With Quote
Old 02-07-2018, 11:30 PM   #6
cas3
the narrow 9" fords from 57ish and early broncos are in demand, hard to find, and not cheap. unless you got 400 hp and like side steppin the clutch the 8" ford is a better choice. mavericks and other mid size fords. any one will be a big can of worms. find it, rebuild it, redesign your suspension, a good banjo sounds pretty easy to me!
