Old 02-01-2018, 05:49 PM   #1
old31
Default torque for u shaped rear hanger spring bolts
I could not find anything in the red book.
What would you torque the two rear u shaped hanger spring bolts to. Or would you just tighten them up?
old31 is offline   Reply With Quote
Old 02-01-2018, 08:03 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: torque for u shaped rear hanger spring bolts
Tighten them but do not install cotter keys yet. Use a 1/2 inch drive socket and a braker bar and put some heft into it.
To insure everything is well seated in, run the car around for a few miles, and re-tighten. repeat three or four times and then install the cotter keys.
That is what I would do.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-01-2018, 09:22 PM   #3
jb-ob
old31,
The spring shop that would re-arch springs suggested after 200 miles to re-torque the spring clamps.
Just went thru the same exercise with a new front spring. Removed the clamps and lower plate, tightened the center bolt and reinstalled the lower plate and re-torqued.
One less on the winter 'to do' list. Winter will end, right ??
jb-ob is offline   Reply With Quote
Old 02-02-2018, 02:16 PM   #4
old31
Thanks guys.
