#61 | |
![]() Quote:
To gain more heat, bolt on an automatic transmission, lock the output shaft, and put it in drive. Run the cooler lines inside to a trans cooler. Run the engine about a 1,000 RPM. The shearing action of the fluid in the torque converter makes a lot of heat. Since we're cutting holes in the wall, add two more and pipe the exhaust inside, through a large muffler, and out again. Use the hottest thermostat you can find. You can even add an engine oil cooler and get back even more from the gas you're burning. How close to 100% efficient would this be??! No heat lost up a chimney! Apply for off road use of fuel and get the hiway tax ($.20/gal. or more) credit. |
#62 |
Personally, I wouldn't use anything that has an open flame. Gas/lacquer thinner, etc vapors can and do get into places you can't put your hand. If I had a propane or NG furnace I would box it in outside the building and duct only the heat in.
I have an in wall electric furnace (fits between studs) in the heated part of my pole building. The heating element is about 7' above the floor and the hot air comes out floor level. I know that isn't temporary but please be careful of anything with a flame. |
#63 |
years ago the neighbor kid had a plugged gas line in his dodge charger. he decided to blow back into the tank with the cap off with air nozzel. did i mention the wood stove at the back of the garage? no more charger...or garage...or house
#64 |
Ralph, be careful around fumes, i have Pulmonary Fibrosis, which is degenerative disease of the lungs, i have breathed in everything welding fumes to DDT, be careful what you breathe so you don't get bad lungs like me, i am on oxygen 24/7
#65 |
I have a Pellet Stove that I got last year. It works really well, uses outside air for combustion & exhaust. In use it costs about 5 bucks a day to operate (all day)
Shop is 24 X 32, fully insulated, except for the (2) 10' doors. Takes about an hour to make it a comfortable 65 degrees. |
#66 |
There are some pretty nice jet heaters out there - just find what's your cheapest fuel to heat with, get the place warm with that than maintain it with the other. Nothing about this hobby is cheap I can tell you that but it's our passion ... (chuckling) .... |
#67 |
#68 | |
![]() Quote:
Many thanks for the info Pat. |
#69 |
Folks; MANY thanks for all the responses, info, suggestions, and details. I just ordered an 80,000 BTU Dyna Glo and 30lb propane tank. Will try it out next week! Again; thanks to all and wishing each of you a very Merry Christmas and a Happy New Year.
#70 |
One advantage to working in the 10 degree temp in my shed yesterday was that I hardly felt any pain when I hit my hand with a hammer yesterday. Typing a little slow today though. :-(
https://www.youtube.com/user/roosty6/videos |
