Old 11-20-2017, 11:14 AM   #1
johndee138
johndee138's Avatar
Default Oil pickup tube for a French block?
Which year oil pickup tube should I use for a French block?
59 AB pan will be used.
Thanks
johndee138 is offline   Reply With Quote
Old 11-20-2017, 12:53 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Oil pickup tube for a French block?
I'd use a 49-53 oil pump and a truck pickup. I used to just bend/weld up other flathead pickups to get them to the right spot - not I just buy this one from Speedway:
https://www.speedwaymotors.com/Speed...Tube,4289.html
Sometimes the pickup bottom is TOO far off the bottom of the pan - should be between 1/4" and 3/8" - I've had to heat and bend some of them.
Good luck!
B&S
