Oil pickup tube for a French block? Which year oil pickup tube should I use for a French block?
59 AB pan will be used. Thanks |
Re: Oil pickup tube for a French block? I'd use a 49-53 oil pump and a truck pickup. I used to just bend/weld up other flathead pickups to get them to the right spot - not I just buy this one from Speedway:
https://www.speedwaymotors.com/Speed...Tube,4289.html Sometimes the pickup bottom is TOO far off the bottom of the pan - should be between 1/4" and 3/8" - I've had to heat and bend some of them. Good luck! B&S |
