Old 11-01-2017, 12:01 PM   #1
Kube
Kube's Avatar
Default '40 convertible top snaps?
Guys, I need (4) four of these. Know where I might get them?
Old 11-01-2017, 12:03 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: '40 convertible top snaps?
I will look and see if I have those.
Yes, the ones I have look to be and inch and a 1/16 c to c on the holes.
I bought a bunch of stuff at Hershey years ago as left over from a convertible restoration, also got round brass vents he said went in the seats somewhere. If these will work I can send them to you.
Old 11-01-2017, 12:21 PM   #3
Kube
Kube's Avatar
Thanks!
Old 11-01-2017, 12:29 PM   #4
deuce_roadster
Can't tell if hole spacing is same as yours. mine, 1 1/16 c to c.
I have 8 of them so would have enough for my car.
I edited previous msg, are brass vents legit?
Old 11-01-2017, 04:00 PM   #5
Kube
Kube's Avatar
Hey Deuce,
I won't be able to check my snaps until late tonight.
The brass screens were "vents" for the back rests (front seat) and were installed at the bottom. They are not visible when the seat is in the "normal" position.
Old 11-02-2017, 08:12 AM   #6
jimTN
Are those break away snaps? The 46-8 have break away's on the rear sides and they are just impossible to find.
Old 11-02-2017, 08:45 AM   #7
Kube
Kube's Avatar
I found them guys thanks to your help. I AM obliged! Thanks much.
Old 11-02-2017, 01:17 PM   #8
Milt/Las Vegas
Milt/Las Vegas's Avatar
I bought 4 snaps from Dennis Carpenter I think.They fit the 2nd set of holes but the not the 1st set of holes on the belt line behind the doors.I bought another pair but they don't fit either.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
Old 11-03-2017, 04:19 PM   #9
supereal
supereal's Avatar
Those are the "self releasing" snaps. I got mine from a local auto trim shop. They are sold by LeBaron-Bonney !-800-221-5408 . Unfortunately they don't aways release as the top is lowered, and should be pulled with the rest of the snaps. I found that out the hard way.
supereal is offline   Reply With Quote
