The Ford Barn
-   -   '40 convertible top snaps? (https://www.fordbarn.com/forum/showthread.php?t=232378)
Kube 11-01-2017 12:01 PM
1 Attachment(s)
Guys, I need (4) four of these. Know where I might get them?
deuce_roadster 11-01-2017 12:03 PM
Re: '40 convertible top snaps?
I will look and see if I have those.
Yes, the ones I have look to be and inch and a 1/16 c to c on the holes.
I bought a bunch of stuff at Hershey years ago as left over from a convertible restoration, also got round brass vents he said went in the seats somewhere. If these will work I can send them to you.
Kube 11-01-2017 12:21 PM
Thanks!
deuce_roadster 11-01-2017 12:29 PM
Can't tell if hole spacing is same as yours. mine, 1 1/16 c to c.
I have 8 of them so would have enough for my car.
I edited previous msg, are brass vents legit?
Kube 11-01-2017 04:00 PM
Hey Deuce,
I won't be able to check my snaps until late tonight.
The brass screens were "vents" for the back rests (front seat) and were installed at the bottom. They are not visible when the seat is in the "normal" position.
jimTN 11-02-2017 08:12 AM
Are those break away snaps? The 46-8 have break away's on the rear sides and they are just impossible to find.
Kube 11-02-2017 08:45 AM
I found them guys thanks to your help. I AM obliged! Thanks much.
Milt/Las Vegas 11-02-2017 01:17 PM
I bought 4 snaps from Dennis Carpenter I think.They fit the 2nd set of holes but the not the 1st set of holes on the belt line behind the doors.I bought another pair but they don't fit either.
supereal 11-03-2017 04:19 PM
Those are the "self releasing" snaps. I got mine from a local auto trim shop. They are sold by LeBaron-Bonney !-800-221-5408 . Unfortunately they don't aways release as the top is lowered, and should be pulled with the rest of the snaps. I found that out the hard way.
