I posted this on the H.A.M.B. because it's about a hot rod. The only responses I have gotten referred me back here.
![]() "I am getting ready to put the clutch and flywheel on the 258" 8BA flathead I built for my "T" tub. I mocked the setup on my bench today ("blocked" the pressure plate and then bolted the pressure plate, disc and flywheel together using the clutch alignment tool and removed the blocks). I then carefully measured the distance from each pressure plate "finger" to the hub of the disc. The three fingers measured 1.225", 1.180", and 1.175" from the clutch disc hub to the contact surface of the fingers. I measured 3 times. All three measurements on each finger were very close and the figures I have presented here are the averages of these measurements. While I would think a difference of .005 would probably be OK, but I don't think the .050 between the highest and lowest to be acceptable. First question : am I correct in assuming that these measurements are out of the ordinary? Second, if they are (and I guess, even if they aren't), how would I go about correcting them? There are no adjusting screws on the ends of the fingers as I have seen on some other units. Do I grind .050 off of the offending clutch finger? There are three bolts that hold the fingers to the clutch assembly; When I loosen them, the end of the finger drops, but I obviously don't want to run loose bolts in my clutch. I would think that a .004 thicker washer (or shim) would bring the offending finger (did I say that?) down the proper amount. Should I be worrying about this or not?" Last edited by tubman; 08-26-2017 at 06:10 AM. Reason: Spelling |
I would measure the clearance between the release bearing and the fingers.
Bruce
Works good Lasts long time |
Like cm posted I would want to see what the measurements were from something like the transmission mounting surface. If you had a bellhousing that mounted to the engine I would measure from the transmission mounting surface of the bellhousing. Guess you could build a bridge across the bellhousing mounting points on the engine and measure from it to the pressure plate.
I would see if you have runout on flywheel,then mount the presure plate (with out the disk),use 1/4" blocks 3 or 4 then measure. They tryed to copy the orginal fingers but was easier to slice them like bread. If you think you can get them all the same go for it.
The Ford instructions I have seen measure from a flat bar across the top of the cover down to the fingers. I do not remember the tolerance, but yours seems way high.
John |
#8 | |
One more thing : Before measuring the bolted together assembly, I laid the pressure plate on the flywheel without the disc and measured the distance from the contact point on the finger to the pressure plate itself. The variation in heights was similar to the variations I got on the assembled unit. There's all kinds of information on the internet about how to adjust tractor clutches and Model A's (where the adjusting mechanism is self-evident). I could find nothing about this kind of clutch. Last edited by tubman; 08-26-2017 at 06:26 AM. Reason: Add more information. |
#9 | |
The hub is not a machined surface. Usually these things are set at the factory. I question whether .050 would make that much of a difference. Try loosening the clutch and reorienting it and see if you get the same measurements.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
I have tried the clutch in all 3 positions and got similar results. What you say about the .050 difference possibly being inconsequential is good to hear. However, if there is a way to adjust it out, I'd like to do it. As I said in a previous post, I also measured from the flywheel (which is a machined surface and got similar results.
The Ford spec requires the use of a flat plate, not a clutch disc, be in place between the PP and flywheel in order to properly adjust the fingers. Obviously the marcel can affect the flatness and influence finger heights.
#13 |
Thanks for the information on the flat plate; I think I can come up with something that approximates the thickness of the clutch disc. Now, if someone has a copy of the manual Bruce mentioned, could you look and see what the procedure is? I don't need a detailed description (though that would be nice); just "grind", "shim", or "something else" would be a good start.
#14 |
I would think that the marcel is not a factor in finger height variation, all it is is a spring steel wave washer and when the spring pressure clamps the disc it flattens it out.
Shimming the yoke of the high lever will lower that finger to the level of the others and since you have two that only vary .005 your fix is relatively easy. Loosen the bolt on the clutch cover that holds the yoke and slip in a shim. The question is how much shim is needed because of the lever ratio, but trial and error will help there. I would use a shim with a forked shape to help keep it in place when tightened. The alternative is to disassemble the PP and mill the two yokes that have the low levers, but I doubt you want to open that can of worms.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
#15 |
Thank you very much "Fordors". I thought that was how it was done, but didn't want to start fooling around with pressure plate until I was sure. Off to my shop I go!
#16 |
I just got back from my shop, and after "Fordor"s advice, I was able to figure out how to adjust the fingers. It is actually very easy. I removed the 5/16"- 1/2" bolt from the pressure plate, and was able to position a .015 spacer over the face of the threaded part inside the clutch. I used a small gauge wire to bring it up over the proper position, and re-inserted the bolt. Everything worked out, but now the finger was .050 low. This is because of the ratio on the clutch fingers. I now think that a .007 shim will put me right in the ballpark. Here is a picture of the .015 shim (which was too thick) and the wire that allowed me to insert it. I am going to find some .007 shims that will bring it into spec.
#17 |
Just as a relatively minor shim thickness change can be significant to lever height, so too is any compressed clutch disc thickness variations. The Ford spec called for differing thickness solid plates for each diameter clutch with adjustments gaged from the PP cover.
Frankly I doubt the heights could be so far off as to cause the clutch to fail to release or engage. You should do what you are happy with whether it is right or not. |
#18 | |
It will not fail to release or engage, the point is to eliminate any possible means of chatter so there is equal pressure all around while the disc is slipping during the engagement procedure.
#19 |
Thank you, Mr. Miller.
#20 |
Thanks to "Ross F1", who sent me some nice stainless steel shim stock, I was able to get my clutch fingers all within .010" of each other. One required .007" while a second needed .002". I think the .010" is about as good as can be done because of the geometry of the clutch fingers. The hardest part of the whole thing was drilling the holes in the thinner shim stock. I ended up punching them with a one of the hollow punches I have for making gaskets. (I think it needs to be sharpened now.)
Thanks Ross, and also "Fordors" who set me on the right track.
