Old 07-19-2017, 08:00 PM   #1
BirchRidge
BirchRidge's Avatar
Default Rod bearings
Pulled the pan tonight and found some babbitt in the oil so I checked the bearings and found this.. How bad is it? Is it over or usable? [/IMG]
BirchRidge is offline   Reply With Quote
Old 07-19-2017, 08:01 PM   #2
BirchRidge
BirchRidge's Avatar
Default Re: Rod bearings
[IMG][/IMG]
Old 07-19-2017, 08:02 PM   #3
BirchRidge
BirchRidge's Avatar
[IMG][/IMG]
Old 07-19-2017, 09:44 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Is that rod centered on the crank ? Possibly more important how much thrust movement do you have on the crank. ( fore and aft)
Old 07-19-2017, 10:35 PM   #5
Russ/40
Russ/40's Avatar
Just my opinion, but if it was mine id put it back and forget I ever saw it.
Old 07-20-2017, 12:36 AM   #6
J Franklin
J Franklin's Avatar
JB-WELD and then check to see how the bearing sits while someone turns the engine over, could have a crooked rod or thrust problem as mentioned. I would use it until it no longer works
J Franklin is online now   Reply With Quote
Old 07-20-2017, 01:35 AM   #7
Synchro909
Synchro909's Avatar
Someone who does Babbit could "dabble" a bit on the sides of that con rod (like soldering, only with Babbit) and adjust the width of the big end to fit the journal. I would do that and keep driving.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-20-2017, 05:58 AM   #8
BirchRidge
BirchRidge's Avatar
Ok, thanks guys.. I will check the rest of the bearings today and see what it looks like.
How much crack endplay is ok?
Old 07-20-2017, 06:06 AM   #9
WHN
How did the engine sound and run prior to finding this?
If you had no idea that anything was wrong, I would do as mentioned above.
Put it back together and enjoy. Might recommend using 20-50w oil.
Model A's run forever.
Old 07-20-2017, 06:20 AM   #10
BirchRidge
BirchRidge's Avatar
The reason I pulled the pan was a knock that I tought was a main bearing since it match this troubleshooting guide http://www.foxvalleymarc.com/Tech_se...ne_noises.html
Old 07-20-2017, 06:26 AM   #11
WHN
Were you hearing the knock all the time.
When spark was fully retarded?
Lugging or pulling up a hill?
Going down a hill under no load?
Old 07-20-2017, 06:44 AM   #12
BirchRidge
BirchRidge's Avatar
It is a "B" engine and dist so I can't retard the spark
It only knocks at normal speed nothing on idle or accelerating
Old 07-20-2017, 07:02 AM   #13
WHN
Some people will question what I am now going to recommend.
If everything else looks good underneath, put it back together.
Use 20-50w oil and add a bottle of STP oil treatment. The STP will help on the flat tapped, and any worn surfaces. Giving the engine some cushion. I also always recommend Marvel Mystery Oil in gas only, helps with valve noise.
I am an old guy that does not like to fix things that don't need fixing.
I have seen and also owned Model A's that knocked. There are cases where Shake Oil will help. If this does not help with the knock, than you can cross that bridge.
Old 07-20-2017, 07:56 AM   #14
Railcarmover
^^^agree^^^,the missing babbit isn't in the thrust area,however the thrust area witness mark indicate a slight misalignment of the rod/rod cap to journal,which could be a number of things,but not worth worrying about..run it,and look for the 'thump' elsewhere.
Railcarmover is offline   Reply With Quote
Old 07-20-2017, 09:23 AM   #15
BirchRidge
BirchRidge's Avatar
Ok, I will check clearence on all bearings again and then start it up and see what happens
Thanks for the advice and answers
Old 07-20-2017, 09:32 AM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with # 13 and 14, except as long as the rod is out I'd have it checked for straightness.
As mentioned, the engine had a slight knock and the witness mark on the babbit looks like a slightly bent rod.
Old 07-20-2017, 05:10 PM   #17
Flathead
Flathead's Avatar
Check the center main?
Flathead is offline   Reply With Quote
Old 07-21-2017, 04:53 PM   #18
BirchRidge
BirchRidge's Avatar
I will check all the mains and rods and report back how it turns out
Old 09-04-2017, 04:38 PM   #19
Fred K-OR
Fred K-OR's Avatar
BirchRidge, did you find out where your knock came from yet? Reason I asked is that I have similar problem.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
