Rod bearings Pulled the pan tonight and found some babbitt in the oil so I checked the bearings and found this.. How bad is it? Is it over or usable? http://<a href="http://forumbilder.s...jpeg?width=150[/IMG]
Re: Rod bearings |
Re: Rod bearings |
Re: Rod bearings Is that rod centered on the crank ? Possibly more important how much thrust movement do you have on the crank. ( fore and aft)
Re: Rod bearings Just my opinion, but if it was mine id put it back and forget I ever saw it.
Re: Rod bearings JB-WELD and then check to see how the bearing sits while someone turns the engine over, could have a crooked rod or thrust problem as mentioned. I would use it until it no longer works
Re: Rod bearings Someone who does Babbit could "dabble" a bit on the sides of that con rod (like soldering, only with Babbit) and adjust the width of the big end to fit the journal. I would do that and keep driving.
Re: Rod bearings Ok, thanks guys.. I will check the rest of the bearings today and see what it looks like.
How much crack endplay is ok? |
Re: Rod bearings How did the engine sound and run prior to finding this?
If you had no idea that anything was wrong, I would do as mentioned above. Put it back together and enjoy. Might recommend using 20-50w oil. Model A's run forever. |
Re: Rod bearings The reason I pulled the pan was a knock that I tought was a main bearing since it match this troubleshooting guide http://www.foxvalleymarc.com/Tech_se...ne_noises.html
Re: Rod bearings Were you hearing the knock all the time.
When spark was fully retarded? Lugging or pulling up a hill? Going down a hill under no load? |
Re: Rod bearings It is a "B" engine and dist so I can't retard the spark
It only knocks at normal speed nothing on idle or accelerating |
Re: Rod bearings Some people will question what I am now going to recommend.
If everything else looks good underneath, put it back together. Use 20-50w oil and add a bottle of STP oil treatment. The STP will help on the flat tapped, and any worn surfaces. Giving the engine some cushion. I also always recommend Marvel Mystery Oil in gas only, helps with valve noise. I am an old guy that does not like to fix things that don't need fixing. I have seen and also owned Model A's that knocked. There are cases where Shake Oil will help. If this does not help with the knock, than you can cross that bridge. |
Re: Rod bearings ^^^agree^^^,the missing babbit isn't in the thrust area,however the thrust area witness mark indicate a slight misalignment of the rod/rod cap to journal,which could be a number of things,but not worth worrying about..run it,and look for the 'thump' elsewhere.
Re: Rod bearings Ok, I will check clearence on all bearings again and then start it up and see what happens
Thanks for the advice and answers |
Re: Rod bearings I agree with # 13 and 14, except as long as the rod is out I'd have it checked for straightness.
As mentioned, the engine had a slight knock and the witness mark on the babbit looks like a slightly bent rod. |
Re: Rod bearings Check the center main?
Re: Rod bearings I will check all the mains and rods and report back how it turns out
Re: Rod bearings BirchRidge, did you find out where your knock came from yet? Reason I asked is that I have similar problem.
