It has slant windshield. Don't mind the parts shelf on the roof or what is left of it.
The windshield can be tilted out, but that isn't a slant body. I don't have a picture handy, but hopefully someone will post a slant sedan picture to compare.
Unfortunately your body will need a lot of wood work, which is quite expensive. |
GOOD GOD! I didn't know you could take the body that far apart without a cutting torch! Mine was almost as bad, but the back end of my body was intact, everything else, not so much. Yes it's a Briggs! Town sedan, I can't say. Does it have cowl lights? a pull down arm rest in the middle of the rear seat? An oval interior light in the rear of the body? These are the defining characteristics of a Town Sedan. A "Standard has none of these. A "Delxue" has cowl lights and something else that I can't remember.
Terry |
Beauford, what you have there is a 'Blindback'. They are very nice bodies but there is no third window hence the name. Lots and lots of wood as you have seen I am sure. They (to me at least) are a very classy body design.
Mike
Here is a side photo of a 1931 160B
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
Fill all of the nail holes with round tooth picks coated in glue. A lot of work, but will give you a surface to tack new nails for attaching the sheet metal |
I think jreloiit is right!!
I've been there. Good Luck. It is entirely possible to save.
Good Luck;
Brian French; 1930 Briggs Town Sedan |
Finished
#10 | |
![]() Quote:
It has the oval interior light in the rear.
The wood other than around the rear window, top side pieces that run over the doors (rot) and a couple of door pieces (missing) are pretty good. If it is a blind back does anyone sell the rear roof metal? |
#13 | |
![]() Quote:
http://www.snydersantiqueauto.com/bo...ood-kits&t=&q= You "wood" (would, haha, get it... never mind ![]() Last edited by Y-Blockhead; 04-26-2017 at 07:42 PM. |
#14 |
Y-Blockhead.....ford wood will sell pieces but they are still extremely high. I have a cabinet maker that could handle the few pieces I need. I'm just going to have a full sheet metal roof made. The stamp on my cowl is August '28. Did they make blind backs then????
#15 |
It seems you have a rather desirable model. I was wondering about the "blind back" and if it might be one. But my lack of familiarity with these models made me wait for someone else's answer. For what it's worth, replace every piece of wood that's even questionable, you'll be happier in the long run. There's nothing worse than a piece of wood that won't take a nail. If that nail isn't fast to the wood in your garage how's it going to be out on the humpy bumpy road? Word to the wise, don't use Oak It swells with changing moisture. Henry used Ash. Some of the wood you don't need a cabinet maker for, like the rear seat base. Good Luck!
Terry |
#16 |
You can contact Berts in Colorado to see what they have as far as sheet metal goes. A long shot (this just a guess on my part) would be to find a donor sedan and cut out the section you need and fill in the window?
#17 |
It's possible it's a 170, because to me it looks like a 30. cowl?
#18 |
Firewall says 8/28 and can't find a '28 blindback.
#19 |
yup...just found one online. Blindback it is! What part of roof from top to around back window is metal and why are these desirable? Is it because most look like this thus no one has the money or time to restore? HAHAHAHA
I have access to cherry wood I am going to use. |
#20 |
It is a blindback. The date on my firewall is 9/11/28. If you cannot find the metal pieces, you could look to an aircraft mechanic who has an English Wheel which is used to form metal.
n the wood pieces, if you are somewhat handy at cabinetry, you could make them your self. Just be aware that there are many complex mortise and tendon joints in the wood so you have to replicate the parts exactly for them to fit. |
