Old 01-26-2017, 08:02 PM   #1
JohnB15632
JohnB15632's Avatar
Default 31 A SW Town Sedan Door outside handles
For those of you out there with four door vehicles, have you install a locking handle on each of the four doors? If you only use the locking handle on the on the driver's front door, how do you lock the other three doors?
Thanks,
JohnB15632 is offline   Reply With Quote
Old 01-26-2017, 08:10 PM   #2
Jerry in Shasta
Jerry in Shasta's Avatar
Default Re: 31 A SW Town Sedan Door outside handles
You lif he inside door handle.
Sorry he does no work
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 01-26-2017, 08:37 PM   #3
Kevin in NJ
My guess is you could make a locking handle for the driver side rear door. Or should I say take a front passenger door lock and move it to the driver rear door.
The design is too different to allow for keys on the other doors.
Old 01-26-2017, 08:56 PM   #4
jm29henry
jm29henry's Avatar
I just have the two out door locks
jm29henry is offline   Reply With Quote
Old 01-26-2017, 09:07 PM   #5
160B
160B's Avatar
Thanks,
The keyed door handle goes on the RF door. On the 1931 Slant Window 160A, B and C the other handles lock by lifting the inside door handle to a horizontal position. See photos
.........unlocked position......................locked position
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-26-2017, 09:07 PM   #6
JDupuis
JDupuis's Avatar
My Canadian early 31 Murray body fordor, only has a key lock on the front passenger door.
All the other doors have the inside lock controls. The reason for the passenger side lock was for safety. Not standing on the traffic side of the car to unlock and let passengers in.
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 01-26-2017, 10:32 PM   #7
duke36
As 160 B and others correctly state, only the front passenger door has a key. The lock mechanism in the other 3 doors (at the handle) has a spring. (see Brattons catalogue or the service bulletins for the orientation ). I had to replace all 3 springs after purchasing the car which was quite a job, so do it while your upholst., etc. is out. Also, the vendors have had some profile and ductile issues with the quality of the "s" shaped springs, so query them about what they have. There are some helpful posts about this on the Barn from others.
Old 01-26-2017, 11:23 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
There are some cities and states that still prohibit the exiting of a vehicle on the drivers side into traffic on the books.
Old 01-27-2017, 12:04 AM   #9
jw hash
jw hash's Avatar
on the SW bodies the original right front door latch assemble is different than all the other lathes. and the original right front door remote has a stop on it, that will NOT let you lock the door on the inside. all the other doors lock from the inside.
jw hash is offline   Reply With Quote
Old 01-27-2017, 09:46 AM   #10
brianpharmd
brianpharmd's Avatar
jw hash - how then do you lock the passenger side door when driving? I like to have the doors locked from a safety standpoint. Seems odd to have to stick the key in from the outside to lock the door.
brianpharmd is offline   Reply With Quote
Old 01-27-2017, 11:09 AM   #11
abachman3
abachman3's Avatar
You unlock the door, open it, reach over and unlock the driver door, then re-lock the passenger door. It remains locked when closed.
abachman3 is offline   Reply With Quote
Old 01-27-2017, 02:53 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
DON'T try to re-invent the WHEEL---Sumbody beat you to it!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-27-2017, 04:41 PM   #13
jw hash
jw hash's Avatar
abachman not quite. the inside right front door remote has a little dog or stop that will not let you lock that door inside. on my Victoria and for other that want to lock that door on the inside. I cut the stop off when rebuilding the latch and remote. also while we are talking the remotes no one and I mean no one that I can find makes the correct spring for the remote. and NOS ones are getting pretty hard to come by.
Old 01-27-2017, 08:34 PM   #14
duke36
Snyder's had a couple of batch runs, some worked Ok, others, the profiles were off and seemed brittle. (post 7)
Old 01-28-2017, 01:51 AM   #15
jw hash
jw hash's Avatar
Bratton`s has the correct profile but there is NO spring in the metal. Snider`s the profile is not correct. I`m willing to pay good money for the correct springs. if someone out there has found a vender that sells the correct springs. please let me know.
