Old 01-04-2017, 10:24 AM   #21
Redbird
Redbird's Avatar
Default Re: timing pin substitute
Where are the pictures?
Redbird is offline   Reply With Quote
Old 01-04-2017, 05:58 PM   #22
[email protected]
wjbgthom@mac.com's Avatar
I have one. I have never posted pictures before so it may take a few tries/Users/wendythompson/Desktop/IMG_0252.JPG
wjbgthom@mac.com is offline   Reply With Quote
Old 01-04-2017, 06:01 PM   #23
[email protected]
Well that did not work , did it.
Let me try again
Old 01-04-2017, 06:04 PM   #24
DougVieyra
DougVieyra's Avatar
"Where are the pictures?"
ZZLEGEND's Post #2* was kind enough to post a link to Snyder's online website's photo of the product they sell. You need to click onto the website link - there you will see a picture of it.
__________________________________________________ ___________
* "Only one I have seen is this one. Don't think this is what you are talking about.
http://www.snydersantiqueauto.com/timing-pin-tool-3669"
DougVieyra is offline   Reply With Quote
Old 01-04-2017, 06:05 PM   #25
[email protected]
mine is nothing like the one Snyder's sells
Bryan Thompson
Old 01-04-2017, 06:16 PM   #26
29spcoupe
29spcoupe's Avatar
Here it is, I found it on my work bench.
made by Bill Jones 937-429-0096
29spcoupe is offline   Reply With Quote
Old 01-04-2017, 06:23 PM   #27
Tom Wesenberg
Tom Wesenberg's Avatar
If there is a spring loaded timing pin that stays permanently in place, does it have an O-ring or seal to keep it from leaking oil?
Didn't someone a year or so back make one that used contacts to light up a bulb, or make a beep when the pin dropped into the dimple?
Old 01-04-2017, 06:27 PM   #28
29spcoupe
29spcoupe's Avatar
[QUOTE=Tom Wesenberg;1409205]If there is a spring loaded timing pin that stays permanently in place, does it have an O-ring or seal to keep it from leaking oil?
This does not have an O-ring. When I am finished with the pin I replace it with the original pin.
Old 01-04-2017, 10:15 PM   #29
[email protected]
This is the pin that came in my car.
Bryan Thompson
Old 01-04-2017, 10:28 PM   #30
Tom Wesenberg
Looks like a well designed tool and the small radius should seal the oil from leaking out.
Old 01-04-2017, 11:22 PM   #31
SeaSlugs
SeaSlugs's Avatar
my only question is how often does one have to fiddle with the timing to warrant a permanently mounted tool?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-04-2017, 11:46 PM   #32
40 Deluxe
Very very seldom, unless you have nothing better to do with your time! First set the point gap to .020". Then set the initial timing according to the Ford procedure in the Instruction Book. All you need is a flat screwdriver and a 1/2" wrench. As long as you keep the points gapped at .020", your timing will not change until the timing gears wear out!
Old 01-05-2017, 01:43 AM   #33
SeaSlugs
SeaSlugs's Avatar
Originally Posted by forever4 View Post
Based on the posts on fordbarn, some people find it absolutely necessary before and after every run for ice cream.
haha I get that vibe too, especially on mystery problems that's the go to is to start playing with it.
I really like the tool 29spcoupe and I have, spring loaded so of you screw it in just enough when it finds the dimple the key ring will pop flat out so you can find dead center of the dimple quite easily just by lookin at it and watching the key ring wiggle.
Old 01-05-2017, 08:58 AM   #34
zzlegend
zzlegend's Avatar
Both of those spring loaded ones look nice. But with one you can use two hands to roll the motor over to set the pin, and the other you still have to hold the pin, unless I am missing some thing. But on the other hand, one can stay in and not be removed, but the other has to be removed and the original pin installed. . So many choices and so little "time". . I think I will stick with the old way I have been doing it for years. Crank engine over to get distributor close, turn pin around, put trans in 3rd gear, hold pin with one hand and slowly rock car until pin drops in. Set timing and take test drive. Come back and find pin laying in driveway due to brain fade. Now where did I put that 1/2" wrench.
Hope I can remember all this since I don't set timing very often. Timing and ice cream is a no, no. Just my 3 1/2 cents. Your timing may vary.
zzlegend is offline   Reply With Quote
Old 01-05-2017, 09:49 AM   #35
Tom Wesenberg
Once you set the timing you can put a dot of white paint on the pulley and another dot on the front cover that lines up to the pulley dot. Now, the next time you just line up the dots.
Old 01-05-2017, 12:09 PM   #36
V4F
V4F's Avatar
I never use my pin . if someone needs one ill give it to you
V4f
V4F is offline   Reply With Quote
Old 01-06-2017, 01:14 AM   #37
Mike V. Florida
Mike V. Florida's Avatar
One that stays put and you push on it to find the dimple (post 29) and the other you use when needed and you watch for the plunger to move (post 26). Each has it pros and cons.
